Removing 99 Civic hub! help
Old Sep 1, 2010 | 09:51 PM
my99ekcoupe's Avatar
Default Removing 99 Civic hub! help
Hey so i broke off my wheel stud today and went online and saw a thread on how to replace it.
So i went to Autozone, and rented their hub puller tool.
I tightened it tightly to the hub, then started screwing in the slide hammer (i think thats what its called). I tightened it as much as i could and the axle just popped out, then i tried hammering the slide hammer since the website said that's how you seperate the hub... and nothing!
Any ideas?
Any chance that my camber kit is too far out and it's making the axle pop out?
Old Sep 2, 2010 | 03:56 PM
Atomic1's Avatar
Default Re: Removing 99 Civic hub! help
You dont need to take off the hub to replace the stud. Just use the washers and bolt trick to pull a new stud through.
Old Sep 2, 2010 | 04:54 PM
i cant get the broken stud off, and there wouldn't be enough space to fit a new stud through..
Old Sep 3, 2010 | 08:33 AM
James_Starks's Avatar
i just changed my wheel bearing and it was a total pain you need a hydrolic press i would do every thing i could before removing the hub try shaving one side of the stud head flat that might work also i dont think you could remove the hub with a puller mine was pressed in and when i did get it out it took the inner race of the bearring with it. hope this helps
Old Sep 3, 2010 | 11:25 AM
yeah, thanks i'm just gonna pull one at the wrecking yard.. they want $45
Old Sep 3, 2010 | 05:28 PM
Atomic1's Avatar
Yes, using a dremel with cutoff wheel is required to shave the edge of the stud, but well worth not having to do all that press work.
ez_steezy
Feb 5, 2005 03:19 PM
ironcheftony
Sep 15, 2003 07:45 PM
SSBP DC2
Mar 31, 2003 10:32 AM
Civiclx
Jan 10, 2003 10:45 AM
gsreatr
Aug 23, 2001 03:28 PM
