99civic ex with ls engine and ECU: Problem with passing emissions in NJ?
Old Sep 1, 2010 | 09:44 PM
anthonyelevenEX's Avatar
Default 99civic ex with ls engine and ECU: Problem with passing emissions in NJ?
just bought a 99civic ex with a ls b18b1 swap in it..bought the car from pa and i live in nj. car has an ecu out of an integra(94-01) and when i go to get it inspected for obd2 emissions(north jersey) it will come up as an integra and they will fail it.(?) am i correct in thinking this..what are my options besides finding a inspection station that i can buy a sticker from.?
Old Sep 1, 2010 | 10:13 PM
Default Re: is there a solution? 99civic ex/ls
anyone know if i put and obd2 ecu in it from a 99 civic it will run decent enough to pass inspection?
Old Sep 2, 2010 | 03:37 AM
94EG8's Avatar
Seagull Management
For any emissions testing I ever heard tell of the ECU must match the engine. and communicate with a scan tool if its an OBD2 vehicle, Make sure you have a USDM OBD2 ECU.
Old Sep 2, 2010 | 05:53 AM
right. but doesnt the ecu have info about the car it was built for? like if they hook up the computer to it wont it say its an integra and they are looking at a civic?
Old Sep 2, 2010 | 06:06 AM
Former User's Avatar
Default Re: 99civic ex with ls engine and ECU: Problem with passing emissions in NJ?
A good thread title helps you get more responses by letting members know what specific information you need:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/threads-must-summarize-technical-problem-title-list-car-details-first-post-2809571/
Thread title edited.
Old Sep 2, 2010 | 06:29 AM
94EG8's Avatar
Seagull Management
Normally I believe they just check for stored CEL codes. IIRC the ECU will just show up as Honda, since Acura=Honda its not really an issue. Either way I think you're over analyzing this. California has the strictest emissions laws and testing in the country and guys there have no problems passing.
Old Sep 2, 2010 | 06:44 AM
i guess i just have to find an ecu thats obd2 and will run good with the ls. any ideas?
Old Sep 2, 2010 | 06:46 AM
94EG8's Avatar
Seagull Management
'96 - '99 ECU will work but require a conversion harness which depending on the state isn't allowed. '00 - '01 ECU will plug right in but has an immobilizer that has to be removed and replaced with a dummy chip, H-T member Katman used to do this for $100 IIRC, PM him for details.
decon
Jan 5, 2017 05:12 PM
anthonyelevenEX
Engine Management and Tuning
Sep 3, 2010 08:24 PM
lsvtec101
Jan 1, 2003 06:39 AM
