Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
stuck under 3800 RPMs
Old Sep 1, 2010 | 08:32 PM
hulsey's Avatar
Default stuck under 3800 RPMs
I was driving down the freeway tonight in 5th gear. I shifted down to 4th to pass a car and the car wouldnt go over 3800rpms. I was thinking this has something to do with the V-tech, but im not sure. Im new to the scene and dont know a lot about hondas. I appreciate any help. Haven't had any problems with my car before. I unplugged the battery for a while and reconnected it but still no change.
Old Sep 2, 2010 | 07:25 AM
toyomatt84's Avatar
Sanji
Default Re: stuck under 3800 RPMs
Do you have a Check Engine light showing? Because if the car won't go over 4,000 RPM's, it is in Limp Mode.
Old Sep 2, 2010 | 06:11 PM
hulsey's Avatar
Yes the CEL is on. Ive tried to reset it but it comes right back on. I have been told it is the vtec solenoid. I took if off and cleaned out the screen on it and its still having the same problem.
Old Sep 2, 2010 | 07:11 PM
jdmfreak1992's Avatar
Matt's right the car's in limp mode. You need the cel codes in order for him to help you.
Old Sep 3, 2010 | 07:54 AM
hulsey's Avatar
the only code that came up was p1259 which has something to do with the vtec.
Old Sep 3, 2010 | 11:08 AM
toyomatt84's Avatar
Sanji
P1259 VTEC System Malfunction
You may have an ECU issue... but I have yet to see that code come up in person.
Old Sep 3, 2010 | 11:51 AM
hulsey's Avatar
Fixed it! Replaced the whole vtec solenoid and cleared the code and it worked. So glad to have my vtec back. Thanks for your help and input.
Michael Ancira
Jan 15, 2017 04:49 PM
Probot
13
Aug 9, 2007 08:38 AM
nosegrindR
Apr 19, 2006 11:28 AM
ninety9ex
Jan 26, 2004 07:40 PM
Rhetoric
Jan 2, 2002 01:10 AM
