I keep blowing passenger side Headlight bulbs WTF?
Old Sep 1, 2010 | 05:22 PM
hondachris1994's Avatar
Default I keep blowing passenger side Headlight bulbs WTF?
as title states it blows the low and high beam light bulbs. It actually shatters the glass on the bulb? Could it b im hitting a bump and they are breaking or would a bad ground cause it? What do u guys think?
Old Sep 1, 2010 | 08:36 PM
gringo7718's Avatar
Default Re: I keep blowing passenger side Headlight bulbs WTF?
Is any moisture leaking into the headlights and touching the bulbs?
Remember that you can not touch the bulbs with your fingers when installing because the oils on your skin can cause the bulbs to break when they heat up. (Clean the bulbs with an moist alcohol cloth prior to installing them.)
Old Sep 2, 2010 | 08:10 AM
yes it does seem that moisture is getting in there, not sure if its getting 2 the bulbs but it is very possible
Honda Gen
69
Jun 9, 2009 02:00 AM
jdmkid_82
May 23, 2006 02:43 AM
Jaypee
Oct 6, 2005 02:31 AM
slowride
Mar 4, 2003 10:56 PM
