Need timing belt advise
Old Sep 1, 2010 | 12:14 PM
efjones9's Avatar
Default Need timing belt advise
my timing belt came loose to the point where it doesnt start anymore. is there anyway that i could just simply tighten it back up? how tight should it be? should i replace the tensioner? im saving up for a swap so i do not want to buy a timing belt.
Old Sep 1, 2010 | 12:22 PM
JacksonD's Avatar
Default Re: Need timing belt advise
Timing belt is like 15 on egay, try re tightening it but if i doesn't start u coulda bent a valve or worse ....
Old Sep 1, 2010 | 12:28 PM
efjones9's Avatar
comp.and leakdown tested it, no bent valves. spark+fuel. the timing just keeps throwing it self off
Old Sep 1, 2010 | 07:54 PM
bfatdaintegra's Avatar
maybe you have a bad tensioner,get a brand new timing belt kit and fix it the right way cause you could smack that valve wit that piston and need a new head too
Old Sep 1, 2010 | 07:56 PM
tjdmcoupe's Avatar
come it its not that expensive, just fix it right and get a new tensioner and belt
Gvis420
13
Dec 20, 2009 12:24 PM
DETALZ
Aug 6, 2007 10:53 AM
b20integrapower
Mar 19, 2006 02:34 PM
JDM_Andrew
Jan 16, 2006 03:30 PM
