i searched for hours
i just replaced my cluch like 8000 miles ago on my z6/y8, si tranny with aftermaket flywheel and now i wana put a t25 on 7psi.can that cluch take it or do NEED to upgrade to a stage 1 or better.also what is the limit for the oem clutches.any info will be greatly appreciated.thank you
let me refraise the psi thing...i want to shoot for 180hp.i want to put in a mitsu t25(from what im told and seen) dsm front mount and bov and im going to run open waste gate..., so from what ive read a 200 hp setup may yield 160 pound of torque(from what ive seen on dyno charts of others).so then 180hp might end up with what,140-150 torque depending on set up and tune....ok so ive heard from a guy who said oem clutches can handle 150 pounds...SO, does this seem like i can use my current clutch for the mean time.
I daily drive a clutch masters stage 4 sprung 4 puck and I get a little bit of chatter in first on slow take-offs and that is my only complaint.
I agree with keep the stock clutch till it goes.
DonReggeaton
18
Jun 10, 2009 03:11 PM
ek_slut
May 30, 2006 04:21 PM
ek_slut
Mar 21, 2006 05:36 AM
Bleed Black
Aug 15, 2002 02:25 PM
...i like it, ill probably get a stage 2 when the time comes... well thanks guys i appreciate your time..
