b18b1 compression
Old Sep 1, 2010 | 12:45 AM
GnArKiLL70's Avatar
Default b18b1 compression
i swaped my 95 hatch with a b18b1 and after getting it ready to fire, it wouldnt start.... so i did a compression test and it went 120-75-75-75 (dry)
so i put alittle oil in the cylinders and it went up to about 180 across, so that means the rings are bad.. i reringed and honed it, and compression is still very bad when i do a dry test but does go up a bit on a wet test... when i did the wet test one cylinder went up to about 200psi then the gauge dropped to 0 and would not build back up..... would a bad head gasket have the same signs as bad rings? what more could it be?
djsimm89
Jun 7, 2013 12:14 PM
SilkyJohnson
13
Feb 15, 2011 05:54 PM
humboldt_skim
May 31, 2008 08:18 AM
Uncle Ben's
Dec 8, 2007 12:21 PM
94_civic_tuner
Oct 10, 2007 02:00 PM
