Creaking Noise from front struts
I recently installed eibach sportlines (used). It's been a month or so and I'm getting a creaking noise when I turn left/right around the strut mount area. I thought a month would be a good amount of time to let them settle in... I got an alignment too. I'm thinking about taking them out and lubing them. Just gotta find the time.
Any thoughts?
Any thoughts?
I had similar problems with my HFP set-up. Couldn't work it out and replaced them with the original system. You might want to replace your bump stops. I think there was an upgrade of them from honda. Good luck!
This^^^
...or I would check all bushings for a 'squeak' before I started spending $$$ on fixes.
edit: or turn up the radio so you can't hear it.... With modded suspensions, noise is par for the course. When you have vibration/shake/jerk in your steerining is when I start to question the setup.
I've seen weird noises come out of the strut mounts.Put it in the air take load of the struts does it still make the noise?Does the noise happen when the car is full load on the wheels stationary steering wheel back and forth in park?
I have yet to find time to disassemble the front struts. I'm gunna try everything you guys tipped me on and get back to you guys here.
there is some civic that do not have a gap in between the the strut tower and the unibody where 3 pieces sheet metal meet and makes noise there is a tsb about this prob.
Took my 2009 Si into the dealership yesterday to get the visors replaced as well as to see what was causing the squeakin sound every time I turned left or right. They said they've ordered replacement strut mounts for both the left and right sides.
So if it's my stock strut mounts, they'll help me out? I had the notion that they would tell me to leave because of my after market springs.
So I bought my Si New in 2009. I bought it in Austin TX, but now that I recall, they said this Si was transported from Corpus Christy. For those of you who don't know, CC is located next to the ocean.
Could this have anything to do with why my Struts began to squeak? Anything else I should look at that doesn't do well with sticky salty air?
Ok, got my Si back on Saturday. Both front struts have been replaced, along with both visors (warping). Now not only does my car drive smooth and quite, but also no longer pulls to the right. I'm a really happy camper right now
I have the same problem with skunk2 springs. We probably need to upgrade our struts. If you compare skunk2 struts/shocks they are shorter than all the others to make up for gap.
Hello,
So any luck yet with the noise issue?
I would try to lube up the ball joints maybe have you tried that?
Get a needle greaser grease it up get back let me no what you came up with..
I have the same issue with Eibach Pro-Kit. I installed them on my car when it had 15k miles and the creaking started immediately after install.
I cut the bump stops as instructed by Eibach and it didn't help. I'm not sure if its the springs them selves. Any ideas?
CivicN3wb
Honda Civic (2001 - 2005)
Jun 9, 2012 11:06 AM
EJAYATE
Jun 19, 2007 06:55 PM
