Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Creaking Noise from front struts
Old 09-01-2010, 12:25 AM
itsalldale's Avatar
Default Creaking Noise from front struts
I recently installed eibach sportlines (used). It's been a month or so and I'm getting a creaking noise when I turn left/right around the strut mount area. I thought a month would be a good amount of time to let them settle in... I got an alignment too. I'm thinking about taking them out and lubing them. Just gotta find the time.
Any thoughts?
Old 09-01-2010, 09:46 AM
BlackFA5Cruiser's Avatar
Default Re: Creaking Noise from front struts
My car just had a control arm repaired and I have this problem as well...
Old 09-01-2010, 05:48 PM
kartman5's Avatar
I had similar problems with my HFP set-up. Couldn't work it out and replaced them with the original system. You might want to replace your bump stops. I think there was an upgrade of them from honda. Good luck!
Old 09-02-2010, 08:38 PM
itsalldale's Avatar
I was thinking about cutting the bump stops or just upgrading them. I didn't think that would do it though. Thanks for the input.
Old 09-02-2010, 11:09 PM
K5^
Brand New
K5^'s Avatar
Steering bearings or check to see the single nut atop the top hats are torqued down completely.
Old 09-03-2010, 11:02 AM
itsalldale's Avatar
I'll double check. Is it possible that the single nut(s) are over torqued?
Old 09-03-2010, 11:23 AM
On vacation
testify's Avatar
This^^^
...or I would check all bushings for a 'squeak' before I started spending $$$ on fixes.
edit: or turn up the radio so you can't hear it.... With modded suspensions, noise is par for the course. When you have vibration/shake/jerk in your steerining is when I start to question the setup.
Old 09-03-2010, 11:26 PM
itsalldale's Avatar
I'll give all of these a check and let you guys know how it goes. Thanks guys.
Old 09-06-2010, 07:08 PM
07Civic.Si's Avatar
Ive seen the bumpstops cut about an inch when installing springs. Dunno if that helps but it might work.
Old 09-11-2010, 11:36 AM
Xxcivic99xX's Avatar
bump for a similar problem i have with the same springs but paired with tokico hp shocks
Old 09-11-2010, 01:13 PM
itsalldale's Avatar
Glad i'm not the only one. Did you get yours fixed?
Old 09-11-2010, 01:20 PM
lastchanceautos's Avatar
Icon6 Re: Creaking Noise from front struts
I've seen weird noises come out of the strut mounts.Put it in the air take load of the struts does it still make the noise?Does the noise happen when the car is full load on the wheels stationary steering wheel back and forth in park?
Old 09-11-2010, 03:39 PM
itsalldale's Avatar
The creaking noise comes when I turn left or right, regardless of it's fully loaded or not. It's most noticeable when I go up and down my drive way first thing in the morning. The noise seems to get quitter as I drive through the day, but maybe its because I'm used to it now :/.
I have yet to find time to disassemble the front struts. I'm gunna try everything you guys tipped me on and get back to you guys here.
Old 09-16-2010, 05:58 PM
honda fossil's Avatar
there is some civic that do not have a gap in between the the strut tower and the unibody where 3 pieces sheet metal meet and makes noise there is a tsb about this prob.
Old 09-17-2010, 11:35 AM
BakerIsBored's Avatar
Took my 2009 Si into the dealership yesterday to get the visors replaced as well as to see what was causing the squeakin sound every time I turned left or right. They said they've ordered replacement strut mounts for both the left and right sides.
Old 09-18-2010, 12:50 PM
itsalldale's Avatar
So if it's my stock strut mounts, they'll help me out? I had the notion that they would tell me to leave because of my after market springs.
Old 09-18-2010, 01:05 PM
K5^
Brand New
K5^'s Avatar
They're going to blame the noise on your springs and charge you for whatever they would have to do.
Old 09-19-2010, 01:47 AM
vladd's Avatar
i would put the stock springs back in before going to the dealer.
Old 09-19-2010, 09:35 AM
So I bought my Si New in 2009. I bought it in Austin TX, but now that I recall, they said this Si was transported from Corpus Christy. For those of you who don't know, CC is located next to the ocean.
Could this have anything to do with why my Struts began to squeak? Anything else I should look at that doesn't do well with sticky salty air?
Old 10-04-2010, 11:11 AM
Ok, got my Si back on Saturday. Both front struts have been replaced, along with both visors (warping). Now not only does my car drive smooth and quite, but also no longer pulls to the right. I'm a really happy camper right now
Old 10-13-2010, 04:01 PM
chasenpaper's Avatar
I have the same problem with skunk2 springs. We probably need to upgrade our struts. If you compare skunk2 struts/shocks they are shorter than all the others to make up for gap.
Old 10-18-2010, 09:47 AM
Icon7 Suspension Specialists Naperville Plainfield Illinois
Hello,
So any luck yet with the noise issue?
I would try to lube up the ball joints maybe have you tried that?
Get a needle greaser grease it up get back let me no what you came up with..
Old 10-18-2010, 11:54 AM
1ll3st's Avatar
I have the same issue with Eibach Pro-Kit. I installed them on my car when it had 15k miles and the creaking started immediately after install.
I cut the bump stops as instructed by Eibach and it didn't help. I'm not sure if its the springs them selves. Any ideas?
CivicN3wb
Honda Civic (2001 - 2005)
06-09-2012 11:06 AM
dohc_profile
11-01-2008 06:03 AM
tico
01-15-2008 03:41 PM
EJAYATE
06-19-2007 06:55 PM
aZnAcCoRd02
05-03-2006 10:36 PM
Quick Reply: Creaking Noise from front struts
