97 Integra with no power
Old Aug 31, 2010 | 10:04 PM
cnj1011's Avatar
Default 97 Integra with no power
1997 integra without vtec. my friend was driving it and broke the timing belt. i put a new belt on and luckly we did not bend any valves. compression is 170 all the way. now it has no power.
i double checked the timing marks and they seem to be dead on.
there are marks on the crank pulley that look like this ( l l l l ) i lined up the last hash mark on the right with the mark on the timing cover and both cam sprockets are pointing straight up.
i plugged in my scanner and all i can see that is out of normal is that the MAP is reading 45Kpa and the ignition timing will reach 55 momentarily when i floor it. at idle the timing is about 15-20
Old Aug 31, 2010 | 11:02 PM
komat's Avatar
Default Re: 97 INTEGRA WITH NO POWER
you line it up with the single mark by itself
when you get hte motor warmed up. you use a timing gun to line it up with the middle line
170psi is pretty low for a gsr
Old Sep 1, 2010 | 09:52 AM
cnj1011's Avatar
ill try that and report back. btw i do not think that it is a gsr. it does not have vtec
another eg
Sep 9, 2015 02:04 PM
BPoppert
Aug 12, 2015 06:52 AM
shark13
19
Sep 23, 2012 11:21 AM
durangedesign.com
Jun 17, 2003 09:10 PM
