What's the reason for switching to a manual T-Belt tensioner?
Old Aug 31, 2010 | 09:42 PM
H23_del_soul's Avatar
Default What's the reason for switching to a manual T-Belt tensioner?
I'm swapping my T-Belt this week and saw that there was a way to swap over to a manual tensioner... my question is should I swap over now while I am changing the belt and everything else? What are the pros/cons of the swap? Now I have an h23, so does that come stock with the manual tensioner? I have done a little reading and I keep getting mixed answers... I also see that there is a way to delete the second belt, what is the reason for this, and what all is required for this to be done?
Old Aug 31, 2010 | 09:43 PM
gstrudler's Avatar
Default Re: What's the reason for switching to a manual T-Belt tensioner?
Yes, the h23 is what has the manual tensioner. Most h22 owners use the manual tensioner out of the h23, so you are good to go.
Old Aug 31, 2010 | 10:46 PM
AdReNaLiN's Avatar
The automatic tensioner from the H22 is known to fail. This will cause the timing belt to go loose and your timing belt will skip causing bent valves...
Manual tensioner, install it, get your timing set right and do it up tight. If you're really worried, put some locktite on and you're good to go.
The second belt turns the balance shafts. Some say its able to be left off with no detrimental effects. I opted to leave mine on when building my engine.
Old Sep 1, 2010 | 12:29 AM
The gates belt kit I bought is coming with one, might as well put it on, lol.
Old Sep 1, 2010 | 08:56 AM
Apex1972's Avatar
its JDM yo
Old Sep 1, 2010 | 11:57 AM
Originally Posted by Apex1972
its JDM yo
Whats JDM... the manual tensioner or my gates belts? I don't think that gates belts are "JDM", I just think there worth the money. I would hate to get the 29 dollar belt form vatozone and be worried when I can spend a little more and be assured. Plus after spending 200 plus on my cam gears, 75 plus on a custom one pulley alt. pulley, and all new accessories that the T-belt touches, whats another 50 bucks for the best belt on the market?!?
Old Sep 1, 2010 | 05:04 PM
sohctodohc's Avatar
my gates waterpump disassembled itself going down the road so good luck with yours!
i will obviously never own any waterpump that doesnt come from honda
Old Sep 1, 2010 | 06:46 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
My Honda water pump diassembled its self going down the road. I will obviously never own any water pump that doesnt come from Gates. (true story)
Old Sep 1, 2010 | 08:10 PM
sohctodohc's Avatar
welp six plus months for me now and havent heard a word back from gates on there "O.E. SPEC" water pump that died in less then 30k miles.
way to stand behind your warrenty guys
Old Sep 1, 2010 | 09:04 PM
I went ahead and got an OEM honda one... much easier that way, lol. Also, don't have to wait for it
the boogler
Mar 25, 2012 06:18 AM
94jdmlude
Dec 22, 2008 01:24 PM
kholmes
Mar 29, 2006 03:16 AM
