Key in chime problem
My keysense seems to be reversed; the alarm that goes off when you leave your key in the ignition; well when I take my key out and leave the door open I get the dinging; I'm just looking to solve the issue
A good thread title helps you get more responses by letting members know what specific information you need:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/threads-must-summarize-technical-problem-title-list-car-details-first-post-2809571/
Thread title edited.
You need to give more details about your problem.
Been a while but I can finally come back to this, my car chimes at me as if my keys were in the ignition every time I open my drivers side door on top of that my front speakers don't work though I've tested them and they are still good. I'm assuming the two are related as thy went out in the same time frame. The drivers side speaker died first then the passenger. So why is this happening, help me fix it. When I get the answer that corrects the problem, meaning I have to verify that it solved my issue; the person responsible willow have $30 sent to them via PayPal.
Chime problem:
My guess is that the key-in switch portion of the ignition switch is stuck closed. Do you have a multimeter to test?
Speakers:
Check the speaker wires at the rear of the radio.
Speakers:
but the factory audio system has nothing to do with the key in chime, does it?? i mean...it's not a Class II gm system. could an electrical spike have cause some issues?
OP...do the rears still work?
does honda audio have protection circuits?? i know OP said front speakers good but how did he check them? speakers good? wiring NOT grounding out. if a channel grounds out will it shut down a stage or just a speaker or the whole radio?
