timing belt install hlp pls!! :P
Old Aug 31, 2010 | 08:12 PM
2kdrift's Avatar
Default timing belt install hlp pls!! :P
okay so i got the head on my d16z6 problem is i dont seem to be lining it up properly. when i cranked it, sounded like it was off
i was using this picture as a guide
mainly i was paying attention to the mark on the bottom part, since theres really nothing up top to line it up to
Old Aug 31, 2010 | 09:44 PM
cibao2ner's Avatar
Default Re: timing belt install hlp pls!! :P
never spin the engine backwards always towards the fron of the car...amd there should be a mark like on the pic on the head to line up the camgear...on d16z6 u might need the cover...to have it 100% right..
Old Sep 1, 2010 | 07:07 PM
2kdrift's Avatar
thanks br0 i didnt even know that part about rotating the engine. also my cam gear ended up looking more like the pic for the d15z1 looking at the bottom timing mark. i do have my timing cover. just after u posted i got it running
Old Sep 1, 2010 | 07:43 PM
v8killaz's Avatar
look on the timing cover and theres should be a mark, rotate crank pulley till you see the 4 marks or slips on it. then line up the one slip thats away from the other 3 to the mark on the cover
do the cam sprocket like the pic
i did my freinds head gasket/timign belt in about 2 hours lol
Old Sep 1, 2010 | 07:44 PM
v8killaz's Avatar
and the cam gear doent matter how it looks on the pic get the up facing up[ and the the 2 lines horizontal lining up with the engine
Old Sep 1, 2010 | 10:45 PM
2kdrift's Avatar
yeah when i realized those 2 lines were not quite horizontal i realized where my cam gear should have been which looks kinda like the z1 pic. also yeaah i was doing the bottom crank the way u said. my problem also was my keyway was kinda loose so i actually used the mark on water pump and lined that up to the crankshaft gear it had a small groove in one of the teeth. i actually ignored the 0 degree mark on my crank. but seems to be running fine now. have to connect the exaust now. i will post pics onto my mini me build thread tomorow. sounds kinda monstarr hehe
Old Sep 2, 2010 | 02:35 AM
v8killaz's Avatar
yeah i wouldn't line the water pump to anything has nothing to do with timing
go off the crank and cam gear its not rocket science it takes like 10 seconds to do it.
if its a stock motor it should sound nothing like a monster.
Old Sep 3, 2010 | 02:37 PM
2kdrift's Avatar
there is a mark on the block that lines to the crank gear maybe it wasnt on the water pump, i think its the oil pump body...my bad but there is a mark. not exactly stock its a frankenstein motor and that was with no exaust hooked up
Old Sep 22, 2010 | 04:22 PM
vrrodri's Avatar
if you moved the crank pulley or cams while installing the belt you probably threw the engine off the right position...need to ensure you have TDC for #1 piston and cams line up as well as crank...
alex1320
Jan 25, 2013 05:54 PM
EGpowa
Jan 8, 2011 10:49 AM
ekwolf1986
26
Aug 30, 2009 07:46 PM
flip b18b
Aug 8, 2003 10:14 PM
