need to run my clutch cable
Old Aug 31, 2010 | 07:39 PM
soon2befast's Avatar
Default need to run my clutch cable
ok my 88 crx was an auto but im doing a manual swap but need to know the specs on how to make the clutch cable hole on the fire wall the only thing i know is that it is by the brake booster
Old Sep 17, 2010 | 08:55 AM
gnxpro24's Avatar
Default Re: need to run my clutch cable
just did this on my 89 civic sedan worked nicely, took time
Old Sep 17, 2010 | 09:23 AM
Jonknee's Avatar
Theres already a hole there
Old Sep 17, 2010 | 11:00 AM
jlk16188's Avatar
the hole already exists. There is a black rubber plug in the hole on the firewall. Its right around the area of your brake booster. its a very easy install, make sure you have the correct pedal assembly that will fit into your car
Old Sep 17, 2010 | 01:46 PM
gnxpro24's Avatar
if you guys are talking about the hole with the plug in it u r incorrect, it is too small for the cable support to go through from the engine compartment, and should exist closer to the brake booster and on the 5 speed cars there is an actual plate with at tube leading to the firewall that attaches to the clutch pedal, you have to take it from a donor car and put it in yours-if u actually want to do it right
Old Feb 24, 2019 | 12:37 PM
Cordell Johnson's Avatar
my 89 civic dont have the hole. So how would i make the hole
Ricextacy
Jan 18, 2012 09:12 AM
DeadboltReX
Classic Hondas
Jan 3, 2012 03:04 PM
Kannan08
Oct 13, 2011 02:32 PM
streetsold6teeny8
18
May 23, 2010 05:00 PM
