Suspension & Brakes Theory, alignment, spring rates....
Need help
Old Aug 31, 2010 | 06:56 PM
760PhatBoyz's Avatar
Icon2 Need help
I just did a rear brake disc conversion on my eg8 and they are hard to spin specially the LR and i already try unadjusting it from the hand brake any advise
Old Aug 31, 2010 | 07:24 PM
Drive 4 fun's Avatar
Default Re: Need help
I am not sure what you mean adjust, try removing e-brake connection at the caliper so that it is out of the picture. Are you saying the pads rubbing?
Old Aug 31, 2010 | 08:40 PM
what i mean is that the e brakes r not reterning all the way back the e brake cables r so tight that i had a hard time getting the mounting brakets to align
Old Sep 1, 2010 | 04:16 AM
Spawne32's Avatar
did you make an adjustment at the handle at all? if you loose it up inside the car, that should free up some slack.
Old Sep 1, 2010 | 04:17 AM
Spawne32's Avatar
woops sorry you said that already lol only thing i could think of holding it up is they are positioned wrong with shortened the cable a bit, other then that, all it is is a cable that needs to be lengthened or shorted. Might need a longer cable.
Old Sep 1, 2010 | 10:14 AM
As Spawne said, you may need a different cable. Your ebrake connection at the caliper is different than stock, and you may not be able to adjust to proper length, but may have to find a different cable that fits. Assuming that you can disconnect it altogether and then the problem is solved, except no ebrake, then it is most likely a length problem.
Old Sep 2, 2010 | 04:59 PM
i think its going to be the cable cuz i got the trailing arm from a 2 door integra and my car is a 4 door
Old Sep 9, 2010 | 02:43 AM
andersenwaka's Avatar
i'm not sure man..........
flyinfree
Sep 9, 2011 08:55 AM
David12
Jul 30, 2010 01:50 PM
jdmboy96
Mar 2, 2009 11:06 AM
coupe_hybrid
May 20, 2006 09:31 AM
01Ntegra
Aug 11, 2004 10:56 AM
