No start; ECU clicking?
Old Aug 31, 2010 | 02:49 PM
zx92027xz's Avatar
Default No start; ECU clicking?
I just finished a one for one swap in my 96 civic dx and I'm trying to get it started. It won't. Turns over strong and all. I have yet to start diagnostics as I had to jet off to class jus now, but one question I had was is there a reason my ecu would be clicking intermittently? I turn the key and it clicks once or twice and then it will click intermittently after that. Ideas?
EDIT:
ECU clicking issue was solved after tightening down the Thermostat ground, as suggested by RONJ@HT.
The spark plugs were worn, so I swapped them out to new plugs.
With a friend adjusting the distributor while I turned over the car (twisting it clockwise, slowly), it fired up. I will have to time it today, but the issue was solved.
Old Aug 31, 2010 | 03:21 PM
Former User's Avatar
Default Re: No start; ECU clicking?
The clicking is probably from the main relay, which is to the right of the glove box.
If the fuel pump does not prime, check for blown fuses (44, 31, 13) and make sure the thermostat ground is clean and tight.
Old Aug 31, 2010 | 03:46 PM
zx92027xz's Avatar
What would cause the main relay to click like that? I will check the fuses and grounds when I get home. Thanks for the help!
winquest1000
Jun 30, 2014 10:10 AM
TexasRoller
Aug 15, 2012 04:38 PM
Nick7
May 14, 2011 08:57 AM
smokingredhatch
11
Jun 22, 2005 05:53 AM
lude97dude
Jan 21, 2003 08:53 PM
