clutch master cylinder issues
Old Aug 31, 2010 | 11:17 AM
Dancing is Forbidden's Avatar
Default clutch master cylinder issues
The car is a 1996 Prelude Si and had no pedal pressure, and when pressing the clutch in the slave cylinder was not moving. I took a look at the master cylinder from under the dash and noticed a nasty leak. There was also not much fluid in the reservoir. Went to Advance and got a replacement. Got the new one in and went to bleed it but there is still no pedal pressure. What to do? Thanks H-T.
Old Aug 31, 2010 | 12:26 PM
chad's Avatar
Moderator
Default Re: clutch master cylinder issues
you have fluid in?
Old Aug 31, 2010 | 12:30 PM
of course there is fluid in there. A friend of mine is suggesting a vacuum bleeder. I've pumped the pedal over 100 times and it does nothing.
JDMswagSerf
Dec 10, 2013 09:47 PM
ocks
Nov 15, 2005 01:52 PM
spooned out
May 27, 2005 12:48 PM
Phillip4285
Feb 1, 2005 07:05 AM
cannan
Oct 30, 2001 11:31 AM
