Need help finding a home for these hoses
Old Aug 31, 2010 | 09:34 AM
SIRIUS VTEC's Avatar
Default Need help finding a home for these hoses
My swaps in the car i just replaced the head and now im left with about 3 hoses which i have no clue as to where they are to go.
Here is a pic of what i mean.
We'll start with this hose first:
All 3 pics are of the same hose, btw
Old Aug 31, 2010 | 09:36 AM
phaphon's Avatar
Default Re: Need help finding a home for these hoses
what motor is it ?? and it looks like it can run to the fitv
Old Aug 31, 2010 | 09:40 AM
Sorry i didnt clrify. This is a D16Y8 same manifold as well. 5-SPEED
Old Aug 31, 2010 | 09:51 AM
IDK but i do know that hose doesnt hook onto the lil pipe in the first picture. Its not flexible enough to turn backwards
Old Aug 31, 2010 | 09:54 AM
Can anyone go outside to there cars and take a look'sy, hopefully im not asking for too much
Old Aug 31, 2010 | 09:57 AM
thesmogman's Avatar
In your first pic you have the hose next to a nipple on the throttlebody. It should run thru the nipple to the other side then to the iacv or fitv as is the case.
It is to warm up the throttlebody when cold
Old Aug 31, 2010 | 09:59 AM
Are you certain SMOGMAN?
I initially had something else going into that nipple that fit more appropriate it was a line that went to the intake tube...
Old Aug 31, 2010 | 10:20 AM
D16SiHatch's Avatar
he's correct. it goes through the bypass under the throttlebody, into the iacv, and then drops down and drains into the coolant pipe on the back of the engine.
Old Aug 31, 2010 | 11:23 AM
Ok so i put it there and started the car now that rubber hose is leaking coolant....Uhh am i even supposed to have coolant in the intake manifold? someone please explain im a lil un easy about it now...i hope i didnt **** up anything..the car was choking.
Old Aug 31, 2010 | 11:48 AM
assistance needed
Old Aug 31, 2010 | 11:49 AM
Former User's Avatar
Coolant hoses:
Vacuum hoses:
Old Aug 31, 2010 | 12:08 PM
thesmogman's Avatar
I guess you missed the last part of my post.
It does not go into the throttlebody I guess you would say it run's next to it! It is not putting coolant into the manifold.
When you pull cold air in thru the throttlebody it will freeze or almost freeze when it is cold out. Igniting cold air with fuel in it is harder than warmed up air. This passage is there just to warm up the throttlebody so it will warm up the air a little as it passes through.
Is the hose leaking or is the throttlebody (TB for short) I would use fuel hose if you need to replace the hose. I believe it to be 3/8" inside diameter.
Old Aug 31, 2010 | 02:29 PM
Ok im learning, i now understand. The anxiety is killin me.
Here's how it sounds starting, can anyone else indicate whether this sounds like a bad battery or something else?
Old Aug 31, 2010 | 02:40 PM
I replaced the head a few days ago and put everything to tdc and changed the gasket of course.
Old Sep 1, 2010 | 07:28 AM
thesmogman's Avatar
Did you move your distributor? It does sound like there is some friction going on. How did you tighten the timing belt? It does sound like the battery is down on power too.
The stroke/compression sounds even, which is a good thing.
Old Sep 1, 2010 | 08:42 AM
smogman, I tried to jump start my battery, I changed the spark plugs, I changed the spark plug wires.
How would moving the distributor effect the starting? the reason i ask is because theres only one way the distributor will fit on the head. I did take the distributor off when i went to change heads. I put it back the only way it fit.
Thanks for ur response
Old Sep 1, 2010 | 09:57 AM
Anyone on right now who could offer assistance.
Old Sep 1, 2010 | 10:04 AM
The starter is laboring to crank the engine. Charge the battery and then go from there.
Old Sep 1, 2010 | 12:15 PM
oK i got it chared over at krage or o;reily..and it's still doing that same thing...whats the next step?
Old Sep 1, 2010 | 12:25 PM
Does the starter now crank the engine rapidly and the engine won't start? If so, check for spark and priming of the fuel pump. Any CEL codes?
Old Sep 1, 2010 | 02:05 PM
the crank seems to have more power than it did before after the battery charge but as i keep trying to turn it over repeatidly it gets lower on power its not as strong of a crank when i keep doing it..Tihs morning i tested the spark plugs from the old motor to a ground...and not one of them sparked at all, then i tried testing the spark plugs from the newer motor and still nothing...Maybe im doing it wrong but it make no sense for the plugs to be bad when they all worked before i pulled the motors do u get what i mean?
What's next....
Yeah the STarter is turning the crank repidly and no it will not fully start...what is that an indication of? Yes i do get a CEL. I think it does prime when i turn the key to the on position i can here the pump.
Old Sep 1, 2010 | 02:11 PM
What's the CEL code(s)?
If you have a 98-00 Civic and the fuel pump definitely primes, then check whether dash fuse 9 is blown.
Old Sep 1, 2010 | 02:13 PM
What would cause fuse 9 to blow? Im not certain how to check for a CEL. ill have to find a tutorial.
Old Sep 1, 2010 | 02:15 PM
Ron, tell me..If the timing belt wasnt tight enough would this be and issue for it not turning over...or would it turn over but drive crappy?
Old Sep 1, 2010 | 02:16 PM
If this helps, I broke a knock sensor but from what i've researched that wouldnt make the car not turn over.
