Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Burning smell coming from passenger side window HELP!
Old Aug 30, 2010 | 10:44 PM
jerBEAR's Avatar
Default Burning smell coming from passenger side window HELP!
So here's the story:
I was driving my gf to class in her 2002 sedan when we noticed a burning smell coming from the passenger side window area after she had rolled down her automatic windows. After I dropped her off, I found that I wasn't able to roll up her window anymore. I began the daunting task of trying to fix the problem.
1st: I checked all the fuses first and found that they were all ok.
2nd: I replaced her window regulator and the window automatically closed by itself without me touching the switch.
3rd: Thinking the switch was bad, I purchased another switch, however I arrived at the same problem, and I am not able to roll down the window.
CLIFFNOTES:
As of now, I have fuses under the kick panel which are all fine, a new window regulator, and a new switch installed, however the window WILL NOT roll down.
Can anyone please point me in the right direction as to what I may have missed as far as checking/replacing parts???
Thanks in advanced to anyone who can help me out!
Old Aug 31, 2010 | 12:36 AM
theineffable's Avatar
Default Re: Burning smell coming from passenger side window HELP!
Did you check the switch on the driver side?
Did you check the wiring for any melting?
Old Aug 31, 2010 | 02:24 AM
civicpraning2k1's Avatar
i had the EXACT same problem and honda misdiagnosed it. try changing the driver side switch. that's the master switch so it overrides everything. if u changed the passenger side and regulator and that didn't work then try to change the driver side switch. see what happens and hopefully this will spare u money on fixing it. Good luck.
Old Aug 31, 2010 | 10:40 AM
jerBEAR's Avatar
Haven't done this yet. Looks like this is going to be my next step. Thank you.
I didn't know the driver was the master switch. Thanks for pointing this out.
Old Aug 31, 2010 | 01:31 PM
yup it overrides all switches.. so when it's bad, ur reg switches won't work.
Old Sep 6, 2010 | 06:11 PM
soon2bdropped's Avatar
change the master switch on the drivers side. should fix your problem.
gqstatus05
Oct 23, 2008 08:51 AM
92ehatch
Mar 3, 2006 02:49 AM
TheIntegraGuy
May 15, 2003 06:18 AM
