Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
MEGAN RACING EZ STREET DAMPER KIT SUSPENSION
Old Aug 30, 2010 | 09:48 PM
ace_drew1's Avatar
Default MEGAN RACING DAMPER KIT SUSPENSION EZ, STREET, TRACK SERIES
Our most recent addition to our expansive coil-over kit line up, the EZ STREET coil-over line up is aimed towards the more budget oriented enthusiast to offer the most basic essentials from an after-market coil-over setup, yet makes no compromises for quality and performance.
Features:
- Spring Rates: 10kg Front and 5kg Rear
- 15 Levels of Adjustable Damper Strength
- Aluminum Brackets paired with rubber inserts
- Rubber Dust Covers
- Adjustable Ride Height
- Conservative Spring Rates
- Single-Cylinder Design - monotube
- All coilover damper kits come with 1 year manufacture-defect warranty.
- All Hardware is Included
APLICATIONS
Honda Accord 03-07 / TSX 03-07
Honda Accord 08+ / Acura TSX 09+
Honda Accord 90-97
HONDA ACCORD 98-02/ ACURA CL 98-03 / ACURA TL 98- 03
HONDA CIVIC 88-00
ACURA INTEGRA 90-01
HONDA PRELUDE 92-01
HONDA S2000 00-09
megan racing street damper kit
Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 levels of damper force adjustment, separate spring perch height and shock length adjustment allowing you to retain full suspension stroke and to fine tune your suspension characteristics. These damper kits are then perfectly matched with front and rear Pillow Ball upper mounts, including camber plates integrated with the upper Pillow Ball mounts on strut-type suspension applications.
SPECIFICATIONS & FEATURES:
APPLICATION:
Honda Civic 1992-1995 EG6/1996-2000 EK9
Acura Integra 1994-2001 DC2/DC4
Honda Civic/CRX 89-91
Acura NSX 1991-1999
Acura RSX Base/Type S 2002-2006
Honda Civic 06+ (including Si models)
an more check meganracing.com
SPRING RATES:
F: 62mm ID; 180mm length; 12 kg/mm
R: 62mm ID; 180mm length; 6 kg/mm
DAMPER SPECS:
F: 95mm stroke; 190mm length; A2 valving code
R: 95mm stroke; 200mm length; A1 valving code
- 32 Levels of Damper Force Adjustment
- Pillow Ball Upper Mounts
- Rubber Dust Boots
- Aggressive Spring Rates
- Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
- All coil-over damper kits come with 1 year manufacturer-defect warranty.
we sale all megan racing product for other cars
Old Sep 1, 2010 | 12:24 AM
ace_drew1's Avatar
Default Re: MEGAN RACING EZ STREET DAMPER KIT SUSPENSION
ttt
Old Sep 1, 2010 | 09:21 PM
ace_drew1's Avatar
BUMP
Old Sep 4, 2010 | 12:33 AM
ace_drew1's Avatar
ttt
Old Sep 7, 2010 | 04:33 PM
ace_drew1's Avatar
bump
Old Sep 8, 2010 | 03:03 AM
ace_drew1's Avatar
ttt
Old Sep 9, 2010 | 04:45 PM
ace_drew1's Avatar
bump
Old Sep 10, 2010 | 07:01 PM
ace_drew1's Avatar
ttt
Old Sep 12, 2010 | 10:41 PM
ace_drew1's Avatar
Old Sep 15, 2010 | 10:36 AM
ace_drew1's Avatar
ttt
Old Sep 16, 2010 | 12:49 AM
ace_drew1's Avatar
bump
Old Sep 16, 2010 | 06:04 PM
ace_drew1's Avatar
TTT
Old Sep 17, 2010 | 02:48 AM
ace_drew1's Avatar
Old Sep 17, 2010 | 10:52 AM
ace_drew1's Avatar
ttt
Old Sep 18, 2010 | 08:13 PM
ace_drew1's Avatar
bump
Old Sep 22, 2010 | 08:02 PM
ace_drew1's Avatar
ttt
Old Sep 23, 2010 | 12:39 AM
ace_drew1's Avatar
ttt
Old Sep 23, 2010 | 05:45 PM
ace_drew1's Avatar
bump
Old Sep 26, 2010 | 07:35 PM
ace_drew1's Avatar
ttt
Old Sep 27, 2010 | 05:19 PM
ace_drew1's Avatar
bump
Old Sep 27, 2010 | 10:33 PM
ace_drew1's Avatar
ttt
Old Sep 29, 2010 | 01:23 AM
ace_drew1's Avatar
bump
Old Sep 29, 2010 | 06:30 PM
ace_drew1's Avatar
ttt
Old Sep 30, 2010 | 04:30 PM
ace_drew1's Avatar
bump
Old Oct 1, 2010 | 10:03 AM
ace_drew1's Avatar
ttt
