car is shaking a lot when i slowly let off the clutch
Old Aug 30, 2010 | 08:36 PM
swizz977's Avatar
Default car is shaking a lot when i slowly let off the clutch
when im in first gear and slowly let off the clutch it starts shaking a lot.. like when u dont press the gas
Old Aug 31, 2010 | 04:43 AM
Former User's Avatar
Default Re: car is shaking a lot when i slowly let off the clutch
The clutch is probably either worn or contaminated with oil or the motor mounts are bad.
Old Aug 31, 2010 | 07:41 AM
eh9deux's Avatar
Well if you're not giving it any gas, it's gonna shake because the motor wants to die out...
Old Aug 31, 2010 | 08:41 AM
swizz977's Avatar
no its shaking a lot tho
Old Aug 31, 2010 | 04:51 PM
honda fossil's Avatar
i would agree with ronj you clultch is prob worn out has oil on it or you have 1 or more bad mounts
Old Aug 31, 2010 | 05:15 PM
BETO_20DA's Avatar
I have to agree with you, my car did the same thing also..I tried changing the front motor mount which was the most worn out and it reduced the shaking but didnt eliminate it..My dad is a backyard mechanic for years and he said that it the clutch that the cause..
Old Aug 31, 2010 | 08:14 PM
hasty91ef's Avatar
proablly rear mount or like everyone else said
Old Aug 31, 2010 | 08:24 PM
CRX Si69's Avatar
well when you don't give it a little gas it will sputter and shake alot.
Jayk00CivicEx
14
Mar 11, 2012 10:26 PM
bl1tzk1213g
May 11, 2007 07:09 PM
kornerk12
Dec 20, 2005 05:47 AM
jsrusse11
14
Nov 7, 2005 10:55 AM
lewd43
Dec 15, 2003 03:37 PM
