Door lock problem with Compustar alarm system
Old Aug 30, 2010 | 07:52 PM
jdm_is_ovrrated's Avatar
Default Door lock problem with Compustar alarm system
i just put the keyless 4dr rear door handles on my 00' coupe
everything is hooked up but for some reason when i go to push my alarm unlock button
the locks open halfway and lock so i cant get in my car unless its through the trunk
i have a compustar alarm and its brand new only a week old
so if any has tried this please try to help me out
thank you
Old Aug 31, 2010 | 12:47 PM
TwoFacedCustoms's Avatar
Default Re: im NEW to honda-tech...NEED HELP
Change your title and people will be more likely to respond.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/threads-must-summarize-technical-problem-title-list-car-details-first-post-2809571/
Old Aug 31, 2010 | 12:53 PM
Former User's Avatar
Default Re: Door lock problem with Compustar alarm system
^Correct.
OP, because you are new, I edited your title.
Old Aug 31, 2010 | 01:04 PM
Did you do the install yourself or did a local shop do it?
Do the locks work using the cars unlock/lock button on the inside?
Did you use OEM actuators or some type of aftermarket actuators?
Do the front locks work fine?
mickey513
Audio / Security / Video
Mar 12, 2014 03:10 PM
ddj
Jan 9, 2013 08:38 PM
HYBRIDCIVIC007
10
Feb 27, 2008 02:58 PM
ley
Honda Civic (2001 - 2005)
10
Mar 21, 2007 04:45 AM
Hunter
Oct 27, 2002 08:02 PM
