Fuel injector install question rsx
Searched w/ no luck, but need info on the new fuel rail studs I need for installing RC Engineering injectors.....Length/thread? Or is there a place I can buy them and the spacers? Any info would be great!
i removed the studs.. and then used longer bolts.. i put the injectors in, and then make sure they are all the way in and then the rail is all the way on.( not bolted ) and then i measure the amount of space between the rail and the manifold and cut a piece pipe stock that length and use it as the spacer. its typically an inchish.
Or, you could give our injectors a shot and not have to worry about spacing the rail. You'll still have to change the connectors on the harness, but we'll include them at no extra charge.
