LS crank in B18c1 block
Old Aug 30, 2010 | 04:51 PM
SLIM NOTHING's Avatar
Default LS crank in B18c1 block
So im currently working on my b18c1 N/A setup and most is done but, i came across a few setups with the LS crank in the bl18c1 block. For some reason i'm thinking for more tourqe? if im not right let me know the reason for this. Also for some reason i mthinking for it to fit it will need to be machined a little? here is the setup lfor the block i am thinking.
81.5 mm CP 12.5:1 cr pistons
H-Beam eagle rods w/ arp rod bolts
Golden Block Guard
ERL 5 Point Main Girdle
moroso oil pan
block will be surfaced
If the LS Crank would be an advantage in this setup let me know. thanks everyone.
Old Aug 30, 2010 | 04:54 PM
4stagecandy's Avatar
Default Re: LS crank in B18c1 block
the ls crank will raise the stroke
Old Aug 30, 2010 | 05:15 PM
ok so then what will need to be done to fit it? also wil it work with my set up? i will also be running close to this head set up.
b18c1 head
skunk2 pro3 cams
performerx manifold (if i only rev to 8.5k)
70mm edelbrock TB
edelbrock fuel rail
kiddracing narrow 4-1 header
stock valves
skunk2 dual valve springs
ported and matched
surfaced.
all tuned with hondata s300
Old Aug 30, 2010 | 05:36 PM
nvm looked up things on the ls crank in the n18c1 sounds like more of a head ache than good for me. so stying with balanced stock crank.
Old Aug 30, 2010 | 07:54 PM
TheShodan's Avatar
Moderator
Don't know where YOU looked, but I did mine without a problem. Just use an oil squirter block kit, match the crank to the rods, and go, go , go. I'm at 12.4:1 on my LS crank GS-R engine and couldn't be happier. You give up too quickly without knowing all the facts.
Here, check this one out. I was able to do it with good planning.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/project-em1-shodan-goes-na-2458563/
Old Aug 30, 2010 | 07:59 PM
lunatics209's Avatar
https://honda-tech.com/forums/showthread.php?t=2458563
^^^Trust this guy. He knows his stuff. He gave me great info and helped me through my 85x89 build (GSR block LS crank). I'm at 13+ compression and just finished my build. Took all the advice from The Shodan and my build went smooth. Dynotuned 263 WHP and 163 TQ.
OP if you have any questions PM me I can help or talk to TheShodan he'll be more than happy to help also.
Old Aug 31, 2010 | 09:24 AM
may i ask what your set up is? im looking for around 220-230hp if i can.
i thought 12.8 or so was getting up there, but your runing 13+, just like the idea of running maybe in the 13+ cr range, but want to know how you do it.
CanoTech88
Sep 7, 2017 07:47 PM
i hate import cars
Oct 26, 2007 07:27 AM
MR. BAR
Mar 17, 2006 01:08 PM
91civicDXdude
12
Nov 4, 2005 03:40 PM
