How to install a B16 VTEC head on a B18A1 block properly
Old Aug 29, 2010 | 09:34 PM
jdm.boi408's Avatar
Default How to install a B16 VTEC head on a B18A1 block properly
I just got a DB1 with a B16 VTEC head on it but I feel it kinda week. And since this is my first vtec I was wondering the things I need to put on the engine soo that the VTEC could kick in hard, because I heard that if you dont install the B16 head right it ends up making your engine loose horsepower.
Old Aug 30, 2010 | 07:16 AM
Project-Honda's Avatar
Default Re: How to install a B16 VTEC head on a B18A1 block properly
Search
Old Aug 30, 2010 | 08:05 AM
Oreo-TeCk's Avatar
try posting or searching in the all motor section.... alot of motor heads in there that are willing to help you out
Old Aug 30, 2010 | 09:50 AM
dapek's Avatar
This has been covered so many times it's getting ridiculous, just do an advanced search and you'll be good to go man.
Simply put, just buy a GE ls/vtec kit, and ditch the headgasket that's included. You'll also have to tap the block for a plug that should be included. Super simple. It sounds like you already have the b16 head on the ls block. You won't achieve the extra power it sounds like your looking for with simple bolt ons, start venturing into internals. Also hopefully he at least put b16 pistons on the ls rods before putting the head on. That could also be an issue.
SIDE NOTE: VTEC should not "kick in hard". Or crack hard like geniuses often say, it should be a smooth transition. Do some research so you'll be better prepared, or else your looking at some reliability issues. GL
Old Aug 30, 2010 | 09:52 AM
gorillafart's Avatar
yeah wrong section *** clown
does H-T have no mods?
Old Aug 30, 2010 | 10:03 AM
dapek's Avatar
Very educated input.
They don't have a large supply of mods on at every given moment able to move the 100's of threads created throughout the day. It takes time like anything else. No need for the anger.
Old Aug 30, 2010 | 10:32 AM
Dapek, you mean tap the head for the plug, not block.
Old Aug 30, 2010 | 05:13 PM
dapek's Avatar
My bad, good catch on the 1/8 NPT plug
jdm.boi408
26
Sep 1, 2010 06:41 PM
harlesjohn
Nov 14, 2005 03:18 PM
dohcivicls
Jul 29, 2005 02:21 PM
eg6T
Nov 22, 2004 05:13 AM
cincispeedemon
Mar 24, 2004 05:41 PM
