Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
A/C Compressor replacement or reseal
Old Aug 29, 2010 | 09:00 PM
jasrams's Avatar
Default A/C Compressor replacement or reseal
Just came in from the a/c repair man and was told that the seal closes to the control arm is leaking so all the gas from the a/c is leaking and was shown by the leak trace they put in the line. So the control arm looks wet. What i want to know is do i have to replace the entrie compressor or can i buy a seal?
Old Aug 30, 2010 | 02:45 PM
It Wasn't Me's Avatar
Default Re: A/C Compressore replacement or reseal
Was he not able to answer this, or did you not bother to ask him?
From what I can tell, you can't overhaul the compressor.
Chances are it would cost more to have it rebuilt (if that is a possibility) than it would to replace it with a used one. New ones are expensive! Remanufactured ones really aren't that much cheaper.
Can you see the source of the leak? Are you sure it's something inside the compressor and not just a leaking o-ring from the suction or discharge lines?
Old Aug 31, 2010 | 06:23 AM
jasrams's Avatar
Default Re: A/C Compressor replacement or reseal
well when i looked on it they told me it had to be replaced because of where it is leaking from so i was just checking for other solutions thanks alot!
MisterBojangles
May 22, 2016 05:11 AM
carguy10
Honda CR-V & Element
Jun 15, 2015 08:31 AM
le0ftw
Sep 1, 2014 06:50 PM
jasrams
Apr 23, 2012 08:59 AM
fromthesun_93
May 6, 2011 06:57 PM
