1997 starting issues
I see these a lot, but I have yet to find a solution to a problem that I am currently having. I have a Honda Accord 97' with a V6 automatic engine. A week ago, I had a chip in my oil pan that leaked out the oil from the oil pan, I drove it about ten miles before the start just suddenly shut off. We towed it back home, we took off the oil pan and fixed the hole and no leaks! But.. the engine will not start. It cranks, and every now and then it catches like it "wants" to start, but it never does. My dad says that the distributor sounds like it isn't turning. Any opinions on what the problem might be? It is currently full of oil, and the oil light is still on. After two seconds of cranking however, the light will go off.
The battery is in very good condition. The spark plugs are fairly new and the cables are in good condition. I was hoping it was something to do with a sensor blocking the engine from starting since the oil light comes on, but I have no idea on how to check that. We tried to reset the computer, but it didn't affect it any.
Let me see if I got his right, the car ran out of oil to the point of shutting off and now it won't start?
I'd add a compression check to the list as well. And be thankfull it is still turning over.
If your distributor isn't turning, its because your camshaft isn't spinning. Yank the dizzy cap and see if the rotor turns. If it doesn't, inspect your belts, see if they have stripped teeth or broken. Because it is entirely possible you spun one or more cam journals. If your cam seized then the belts will be stripped.
Oh, and the oil light shows up when you have no oil pressure. The oil pump doesn't pressurize the system if the engine won't start. Crank it, and pressure shows up. Stop and it goes away.
BuddhistPriest87
Honda Civic (2006 - 2015)
Feb 10, 2012 02:40 PM
djnikko
Mar 18, 2004 03:56 AM
I will try it when i get home this evening.
