97 CX hatch SRS light is on after swap 97 EX coupe cluster?
Old Aug 28, 2010 | 08:46 PM
XYFLZ's Avatar
Default 97 CX hatch SRS light is on after swap 97 EX coupe cluster?
Right after I put 97 EX cluster on my 97 CX hatch, SRS light turns on. Anyone knows why?
Old Aug 29, 2010 | 06:54 AM
canadaek's Avatar
Default Re: 97 CX hatch SRS light is on after swap 97 EX coupe cluster?
did you turn the key on with the cluster unpluged ?? and mae sure the yellow connector is pluged in all the way
Old Aug 29, 2010 | 06:57 AM
XYFLZ's Avatar
I already installed the cluster. i have been driving with SRS light since day one.
Old Aug 29, 2010 | 08:36 AM
canadaek's Avatar
i would pull it out and make sure all the connectors are in right . and have you tried unhooking the battery ?
Old Aug 29, 2010 | 08:38 AM
XYFLZ's Avatar
I just pulled out and checked all the plugs. they were fine. there was two blue connectors and one yellow connector. Yea i unhooked the battery a couple times when i cleaned IACV. But no use.
Old Aug 29, 2010 | 12:27 PM
HondaPartsHero's Avatar
Technical Hero
http://www.clubcivic.com/board/showthread.php?t=115880
Old Aug 29, 2010 | 04:27 PM
XYFLZ's Avatar
thanks^. great link. so everyone who swap cluster have to reset their SRS
Old Aug 29, 2010 | 04:46 PM
Technical Hero
I just swapped my dx for ex with no problems
Old Aug 29, 2010 | 11:26 PM
HondaImplanted's Avatar
Icon7 Re: 97 CX hatch SRS light is on after swap 97 EX coupe cluster?
Originally Posted by HondaPartsHero
Thaanks - QuickGuide Manual helped me out so well, all I had to do is to lay under the fuse box and use my fingers with paper clips, all took less than a minute and bang I have all sorted! Excelent!
Thanks for the link!
User 12720
Jul 26, 2006 09:50 PM
