Seeking to hit 500 whp. Input please!
golden eagle Sleeved b18c1
84mm bore
9:1 arias pistons
eagle rods
acl bearings
integra type r head With ctr cams
b16 tranny with a stage 5 cc.
Only two things that worry me are the
Single walbro with aem fuel rail with fpr.5zigen wheel
750cc rc injectors.
Just those 2 things worry me.
Turbo is 62/62 precision turbo. .70 A/R .63
so I'm hoping to hit 500 on pump! So please let me know what you know or have experienced. Thanks
84mm bore
9:1 arias pistons
eagle rods
acl bearings
750cc rc injectors.
With what kinda tuning? Hondata? Ectune? Neptune? Im on the same quest. I have a fully built ls/vtec....1000cc precisions, garret 60-1 .70 ar....
Been running the car with the 255 for over a Year. I made 492 on 19psi 520 on 20.5 psi but turned the boost back down to 19 incase i got a bad tank of gas. It was on 93 pump. I wouldnt worry about the walbro at all just get the 1000's and you should be good to go
Your missing some info on your setup, like turbo mani, wg, ect. But as far as fuel, I would recommend Injector Dynamics 1000cc injectors, heavier guage power wire for pump, mabey even a 044 inline pump. Other things that will make a big difference on turbo cars in that range are the intake mani(victor-x are good) and cams( like skunk2 tuner 1s). just a few tips, but hope it helps
ok cool so on that power for a year you havent had any problems with the walbro. Thanks for all the input.
captainjdog
Sep 2, 2004 04:39 PM
