WTB: DC4 teggy tail lights harness/gaskets
Im looking for some tail light harness's and bulbs and the gaskets.. Thanks. I want it all.. not looking to spend much used will do as long as its in good shape.. Thanks. also sum nuts if you have them...
now im looking for a set of tail light gaskets and the harness's for both sides + bulbs.. Thanks. keep it cheap..
LMK i need them how hard can it be to find some wiring harness for the Tails and gaskets/bulbs... Shipped to Iowa
I have a totaled integer the rear end is good tho so I'm sure I have them what do u mean by harness tho Does it unplug from the rest of the body harness?
Yeh what i need is for you to remove your tail lights and put the little nuts in a zip lock bag and pull them out then remove the gaskets of both sides and the unscrew the bulbs and remove the bulbs and the harness form the lights.. So just keep the bulbs inside the harness clips I need all that.. Thanks. Bulbs Harness on both sides nuts and gaskets Thanks you do have it all... I just about bought a parts car.
damn you should have sent me a pm cause i dont usually check posts. i have my car at a freinds an hour and half away from were i live and i was just down there this weekend i coulda got the stuff. i probably wont be down there again for a couple weeks.
jdmspoonitr
Jan 18, 2005 06:39 PM
