wont shift!
Old Aug 28, 2010 | 07:10 PM
F20B_accord's Avatar
Default wont shift!
so my car shifts for a few times then it wont shift at all and i cannot get it into gear? it doesnt make any noise and i dont have any leaking mc or sc.. umm no noise either however it does grind the gears if i try to force it into gear. anything? thanks
Old Aug 28, 2010 | 09:09 PM
Default Re: wont shift!
comme on ppl plzz lol i need your help i check tranny fluid and changed it. hmm shifting cables are okay
Old Aug 28, 2010 | 09:43 PM
hondawhiz's Avatar
clutch is out??
if the car is off does it shift normal?
bseriescrxsi's Avatar
your clutch is not properly engaging/disengaging.....do you have pressure on the pedal? how old is the clutch? is the slave cylinder bolted in with 2 bolts?(yes people try to half *** it and only put one in) have to confirmed the the slave cylinder is actually pushing on the "fork" that goes into the trans? when in neutral do you hear a humming/almost grinding?(could indicated bad throw out bearing)
Old Aug 28, 2010 | 09:45 PM
yay! yeah it shifts when off, right before it happened i shifted from 7k 1st to 2nd than 3rd and then it wouldnt shift into gear but somehow i made it home. now i am able to only shift it in a couple times then boom doesnt work. i also just replaced an axle
Old Aug 28, 2010 | 09:47 PM
hmm bseriescrxsi for the slave cylinder yes i checked it and it does in fact push against the fork. i also have pressure on the pedal and the clutch is stock for 80k umm also i will have to check the humming tomorrow as its late but thank you both for the reply
Old Aug 28, 2010 | 09:48 PM
i would say your clutch is in need of replacing and has little to no material left on it but without all the specifics can be 100%...after your last post im leaning 95% toward clutch as we have taken a pressure issue out of the equation
Old Aug 28, 2010 | 09:53 PM
hondawhiz's Avatar
yes i agree. sounds like the clutch is out. did u check the mc from the inside of the car to make sure its not leaking inside?
Old Aug 28, 2010 | 09:56 PM
yup checked it clean as anything, hmm clutch darn lol
Old Aug 29, 2010 | 10:16 AM
okay so i got some new updates. the car shifts perfectly now and drives pretty sure it was just the tranny fluid. but now my car is making a grinding noise when it moves forward, could this be the cause of an improperly installed axle??
Old Aug 29, 2010 | 11:00 AM
02 accord's Avatar
If the clutch had no material left, then it would be slipping while driving. His symptoms coincide with the clutch not disengaging completely. Tranny fluid has nothing to do with this. It seems like you have a problem in the hydraulic system (master/slave cylinders).
Old Aug 29, 2010 | 11:43 AM
yes thats make sense because the slave cylinder squeaks. i shall replace this and see what happens, thank you!
Old Sep 4, 2010 | 04:58 PM
okay so i took it for a test drive to my friends to drop the tranny and it shifted perfectly so i no longer need to drop it, however this ONLY happens when i take off for about 2 seconds until the car gets rolling it makes a grinding noise?
Old Sep 5, 2010 | 06:55 AM
hondawhiz's Avatar
sounds like you fried the main shaft bearing from inside the tranny, cuz you ran it without fluid.
Old Sep 5, 2010 | 07:31 AM
i never ran it without fluid lol...
Old Sep 5, 2010 | 07:49 AM
but some more details: goes into 1st perfectly, press gas and release car starts to grind at the front passenger wheel once foot comes off clutch it doesnt grind anymore.
99hondadx
Feb 10, 2017 05:35 AM
graftuner34
Feb 28, 2007 12:56 PM
scrap1ngsr
Apr 5, 2006 10:41 AM
91_2.0_Si
May 20, 2004 07:05 PM
b20civic
Apr 14, 2003 12:43 PM
