Expansion valve
Old Aug 28, 2010 | 10:57 AM
TurbodreamZ's Avatar
Default Expansion valve
I need the replace the expansion valve on my 99 civic. I removed the glovebox and everything but theres one more bolt on the top that cannot be reached with normal tools. Do I have to remove the ENTIRE dash to remove the evap box?
Old Aug 28, 2010 | 06:03 PM
Matt93eg's Avatar
Default Re: Expansion valve
Unless the 6th Gen civic is totally different than the 5th then the answer is No.
On a 5th you can pull the Evaporator out with the dash in place no problem. There is a bolt up high that I use a long extension to get.
Old Aug 29, 2010 | 10:29 AM
hmm looks like im going to get creative to get the top bolt off. thanks
Old Aug 29, 2010 | 03:16 PM
Finally got it off. I had to use a 3/8'' wobble extension, swivel joint, and finally the short 10mm. you have to squeeze your free hand and guide it onto the nut.
Animefun
Oct 28, 2012 08:55 PM
ramos2589
Feb 13, 2008 11:50 AM
hondaracin24
May 10, 2005 04:38 PM
Kavehman
Oct 7, 2004 07:55 AM
