1999 Acura Integra GSR Part-out (Tan Leather, Dark Green)
For sale
1999 Acura Integra GSR Interior and body parts
Interior:
Dashboard with harness and airbag $135
Both Airbags and SRS unit and Harness $140
Center Console Front Half Only (Price Dropped) - $35
A-Pillars $20
B-Pillars $20
Trunk Plastics $35
Glove Box $45
Steering Column with ignition swith & key $90
Steering Column Plastics $30
Dome Light $10
Map Light $10
Clock $15
Exterior: (Cypress Green)
Passenger Side Door (no window motor) $100
Front Core Support(including Front half of inner fenders) $115
Front Bumper support $45
Rear Bumper Support $45
Harness ALL UNCUT
Body harnesses that go inside along the floor on both sides of the seats, goes to the back across where the taillights are and the one that goes up into the hatch to feed the rear wiper and defroster. also have defroster ground wire $80
I do not have the engine harness
Rear Bumper Older style Flat Bottom (Missing some paint, no deep scratches, holes etc...) $65
Spoiler (Passenger side mounting bolts are detached, still have them. OEM Honda) - $45
Under the hood:
Radiator Fan $25
Condenser Fan $25
Air conditioning Condenser $35
Power Steering pump $40
Power Steering Rack $115
Clutch Master Cylinder and Reservoir $65
ABS Brain and Distribution cylinder $50
A/C Lines (From condesnsor to evaporator and back) - $55
Battery Tray and Holddown - $25
Clutch Line (From master cylinder to slave cylinder) - $20
Windshield Washer Reservoir and pumps - $20
ABS Proportioning Valve - $20 or trade for rear disc non-abs prop valve
Cruise Control unit and cable - $40
Front Wiper Arms - $20
Rear Wiper arm and motor - $40
Front Subframe - $110
Pedal Assembly - $65
Windshild wiper motor $35
Cowl $25
Fuse box(underhood) $20
Gas Tank(with sending unit and fuel pump)and straps $85
Gas tank filler neck and cap $25
Sunroof motor and glass(complete unit) $120
Headliner(small hole) $25
If you dont see something small listed then ask i might have it, as for bigger parts i'll list at the bottom what is gone. thanks for looking!
If you need pictures or have questions email me at napster56754@aol.com and include in the subject your from hondatech about the integra.
I will respond to pm's however i do not know how to send pictures through them.
Please bump if you look!
Interior:
A-Pillars $20
B-Pillars $20
Trunk Plastics $35
Glove Box $45
Dome Light $10
Map Light $10
Clock $15
Harness ALL UNCUT
Under the hood:
Radiator Fan $25
Condenser Fan $25
Cowl $25
B16Civic93
Mid-Atlantic (Sales)
62
Apr 18, 2011 09:42 AM
B16Civic93
Oct 24, 2010 06:15 PM
B16Civic93
27
Oct 13, 2010 01:49 PM
B16Civic93
42
Aug 27, 2010 01:09 PM
