H22a swap! Need to sell asap!
Got some goods.for sale. Everything is obo!
H22a block
- block turns over fine now that its out of the car
-comes with brand new from Honda
2 pistons, rods, bearing set, and ring set
-brand new water pump and timing belt
- balance shaft removed
- comes with obd1 and obd2 oil pumps and dizzys
300 obo
Fresh head from machine shop
-has a mild port job -sold
-new valve seals
-arp head studs torqued once - sold
-new head gasket - sold
Tranny was said to have slight third gear grind. Most likely low on fluid. - 200 obo
-new oem exedy clutch - sold
-new 8lb fidanza flywheel - sold
Also have
Tapped oil pan - 50 obo
Brand new H series to EK motor mounts - 250 obo
Might have more junk laying around. Make some offers. Looking for 1200 for everything. I can include axles, harness and shifter and cables for someone looking to do a swap.
Yay for cell phone pics:
H22a block
300 obo
-new valve seals
Also have
Which mounts/axels are they for the H into EK? Also, do you have an uncut/unmolested engine harness for the H? Finally, the shift box/cables, if available I'd grab that as well.
bump none the less for some good parts.
b1_teg_god
Northwest (Sales)
18
Jun 7, 2009 05:00 AM
sebringsilvers2k
Feb 15, 2006 12:05 PM
