fuel pump not doing anything
Old Aug 27, 2010 | 06:38 PM
andocommando's Avatar
Default fuel pump not doing anything
does my dash need to be in for the motor to get fuel?
Old Sep 4, 2010 | 02:38 AM
virgineg6's Avatar
Default Re: fuel pump not doing anything
if the harness is all their and connected the dash dont matter, check for power and ground at the pump if both check good replace the pump. if 1 of those doesnt check out its probably a loose pin somewhere or a broken wire.
Old Sep 4, 2010 | 04:58 AM
Former User's Avatar
Check for blown main relay fuses, resolder the main relay, and check whether the G101 thermostat housing ground is clean and tight.
Old Sep 4, 2010 | 05:09 AM
BryanM.'s Avatar
Resident Gearhead
Ron can you post that great DIY Main Relay Resolder link?
Old Sep 4, 2010 | 05:12 AM
HondaPartsHero's Avatar
Technical Hero
http://techauto.awardspace.com/mainrelay.html
Old Sep 4, 2010 | 05:14 AM
Here you go:
hondabch
Aug 17, 2015 05:26 AM
koffeedc2
15
Feb 10, 2015 03:56 PM
thakid
Dec 27, 2010 06:08 AM
insomniac791
Jan 22, 2004 04:23 PM
1hottEG6
Apr 11, 2003 02:19 PM
