Intermitant problem (Need help diagnosing issue)
Old Aug 27, 2010 | 02:18 PM
DocShay's Avatar
Default Intermitant problem (Need help diagnosing issue)
Hey guys,
Hope this is the right part to post this in. Please move if it is not.
I have a 1998 Honda Civic SI (EX in US model). While driving, car looses all power at once. CD player, lights, even my gauges die out. Motor will still run though. (Although I find somewhere to park ASAP).
If I try and start the car immediately after this, nothing will happen, except I will get accessory power. If I wait a few minutes (5-10) when I try and start it, it will "click" (starter) but wont turn over. I've left it overnight 3 times when this has happened, once while charging the battery and other 2 I did not - and it will start and go no problem for a few days.
Notes:
- No lights (battery, engine) flash or go on solid when any of this happens
- Alternator was replaced last year
- Had battery tested, tested just fine
- Thought it may be a bad battery connection as my positive cable was frayed, replaced it.
I have a sneaky feeling I may be overheating and having a cooling issue - Dumb moment but I never checked my temp gauge. If I can start my car (going back to it in a few hours) i'll check it out - otherwise i'm not sure what it may be.
Any thoughts guy? I'm just about at the point to get it to my mechanic, but figured i'd try and fix it myself first.
Thanks,
Shay
Old Aug 27, 2010 | 07:34 PM
DocShay's Avatar
Default Re: Intermitant problem (Need help diagnosing issue)
Bump
Went back to my car, was able to start it no problem. Drove it home (5mins) and temps seemed fine, although its night now and cooled off abit and I didn't drive far. Might go for a longer drive later and see if the temps go high.
any ideas guys?
Old Aug 27, 2010 | 10:52 PM
mortificationrock's Avatar
Maybe ELD?
Old Aug 27, 2010 | 11:04 PM
DocShay's Avatar
Won't lie, I had to google what that part was.
Seems though if I had an issue with that my battery would be shot by an ongoing issue with that, yet the battery remains just fine.
Just seems weird I can just let it sit, and it will start up and drive just fine for a few days. I took it for a 10 minute "spirited" drive to see if I could get the temps up (also left it ideling first for 10 minutes) and my temp gauge never moved above just under half (where it usually sits).
Such a strange problem. I wish cars could talk
Old Aug 27, 2010 | 11:34 PM
Go get your alternator tested. A heating problem has nothing to do with a voltage charging problem.
Old Aug 28, 2010 | 12:25 AM
DocShay's Avatar
Will do, sucks I have to wait til monday though.
When my alternator was dying last year I remember my battery light flickering - This hasn't happened this time around. Would that have anything to do with it?
Old Aug 28, 2010 | 02:31 PM
DocShay's Avatar
Any other suggestions until I can get it fixed monday?
Old Aug 28, 2010 | 04:13 PM
94EG8's Avatar
Seagull Management
The engine harness on '96 - '99 Civics were notorious for rubbing on the intake manifold bracket under the intake manifold and causing all kinds of funky issues.
Old Aug 29, 2010 | 01:07 AM
EnderAW's Avatar
While you are having the alternator checked, have them check the battery, I'm sure that they will test is just after your drove it, and it will pass with flying colors, because it has a surface charge on it. Have them retest it after cranking the car for about 10 seconds, that will get rid of that surface charge, and will tell you the true state of your battery.
Old Aug 29, 2010 | 01:36 AM
D3vin's Avatar
Check your battery. It could be a bad ground. I straight up grounded the starter to the battery and it runs perfect. Before, my car wouldn't crank but everything else works. Eventually, I took the starter out and hooked it straight up to the battery. I noticed that the starter will extend out making the loud "click" noise and another wire from the harness which sends a signal for it to spin.
Old Sep 4, 2010 | 02:11 AM
virgineg6's Avatar
intermitant problems are the worst, because everthing checks good but the problem will still exist. try getting the battery and alternator checked when the problem arises, if possible.
Old Sep 4, 2010 | 05:13 AM
Former User's Avatar
Test the ignition switch:
r4in
Jan 3, 2014 09:27 AM
homegr0wn
May 15, 2012 05:47 AM
General Kills
Aug 21, 2008 12:18 PM
koleah
Oct 2, 2005 02:33 PM
koleah
Sep 30, 2005 07:43 AM
