integra mount or civic mount - newb quest please help
Old Aug 27, 2010 | 01:25 PM
iwannarace's Avatar
Default integra mount or civic mount - newb quest please help
I bought a 91 hatch with a b18a1. Has Arizona Race & Machine mounts in it now. They vibrate way to much so I was considering replacing the rear firewall AzRace mount with an OEM one. I'm not sure if I get the OEM Integra mount or OEM Civic mount. I searched and could't figure it out.
Thanks for the help.
-Mike
Old Aug 27, 2010 | 01:30 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: integra mount or civic mount - newb quest please help
You know, that's a good question!!! From what i can remember, the rear cross member does have two mounting positions for the rear mount, it may be the one that you could get away with using an oem part, but don't know for sure
The other thing you might be able to do to help with vibrations, is to turn the idle up a couple hundred rpm
Old Aug 27, 2010 | 01:47 PM
iwannarace's Avatar
While searching HT several users suggested replacing one of the rear mounts with an OEM one to reduce vibration. I assumed it was the rear one. Is there another one I can replace to reduce vibrations aside from the left and right side mounts?
The idle's already pretty high and it helps but the interior is like a 4/10 from 4 years of vicious vibrating. I just would liek to reduce it as much as possible since this is my commuter.
Thanks
Old Aug 27, 2010 | 01:55 PM
phatrick2332's Avatar
I am pretty sure that the reason there are two sets of holes for the mount bolts is because one is auto the other is manual.
I don't believe there is a way to use an oem rear mount.
Old Aug 29, 2010 | 09:09 PM
iwannarace's Avatar
What about a jdm b16a rear mount out of an sir? If I could source one might that work?
Old Aug 29, 2010 | 11:46 PM
hatchet_honda's Avatar
teg rear mount wont work im sure...oem civic mount either its a bit over too far. get an aftermarket rear swap b mount
Tim2179
Nov 1, 2010 09:57 AM
97BB6Type-SH
May 21, 2008 04:53 PM
BoltonGSR
Mar 7, 2008 05:52 AM
mattL
Jan 7, 2004 11:12 AM
erniecars
Nov 14, 2002 02:38 PM
