Quick flash of oil light, why?
Old Aug 27, 2010 | 09:44 AM
The Collin's Avatar
Default Quick flash of oil light, why?
Vehicle: 1999 Honda Civic CX
Mileage: 117,500
Engine: Stock
When I start my car, all instrument lights come on and then go off( as typical ), then the oil light flashes on/off quickly after it has started. I've never noticed this before, up until about 2 weeks ago.
I changed the oil about 1,500 miles ago. There are no leaks, and the level is good.
The car is running fine, I just wonder why it's doing this. If it's a sign of something going to possibly go out soon, or if it's because of the recent temperatures here in OK (100+), even though it's garaged, and it's been in the high 80's-lower 90's recently.
Old Aug 27, 2010 | 09:54 AM
The Collin's Avatar
Default Re: Quick flash of oil light, why?
I did some research, and it seems maybe it's possible that the Fram filter I used is causing this because of an anti drain back? I've used these before without an issue.
Old Aug 27, 2010 | 11:11 AM
94EG8's Avatar
Seagull Management
i've seen it before where all it was, was the oil filter.
Old Aug 27, 2010 | 11:17 AM
The Collin's Avatar
I think I am going to hook up an oil pressure gauge and see if the readings fall within spec. It doesn't do it every time I start it, either.
Old Aug 27, 2010 | 12:22 PM
tico's Avatar
could be the use of a cheap oil filter.i always use a OEM or HAMP filter. and remember OEM spec pressures are withe the use of an OEM filter
Balor_Gr
May 17, 2017 04:20 PM
rc1991
May 9, 2014 06:32 PM
rylamar
Dec 14, 2009 06:06 AM
twentyhurtz
Oct 18, 2007 05:11 PM
