Gauge Cluster Problem - 00 Ex vtec with 98 ecu
Old Aug 27, 2010 | 08:56 AM
soccermike's Avatar
Default Gauge Cluster Problem - 00 Ex vtec with 98 ecu
Can anyone tell me if it is possible to use the auto ex cluster that i had? i just swapped my car from auto to manual and i couldnt get the tach to work. I ended up buying an manual 97 integra cluster hoping it would work, but i havent gotten it to light up and the tach on that still doesnt work. Any suggestions?
Old Aug 27, 2010 | 10:55 AM
Former User's Avatar
Default Re: Gauge Cluster Problem - 00 Ex vtec with 98 ecu
The 00 ECU sends the signal to the tach but the 98 ECU does not. The 98 cluster instead gets the tach signal from the ICM inside the distributor.
Old Aug 27, 2010 | 11:09 AM
94EG8's Avatar
Seagull Management
Yep, really has nothing to do with the cluster itself, has to do with the engine and cabin harness. you can add a wire to the empty terminal on the igniter in the distributor and run it to the tach test wire at the driver's side rear corner of the engine bay and it should work fine. Or get a '99 - '00 EX ECU
Old Aug 29, 2010 | 06:29 PM
soccermike's Avatar
ok, thanks for the responses guys...now as for running that wire...was i wrong to think that i could tap a wire off the blue wire coming off the distributor and run that to the test wire? because that is what i did, and i all i got as my result was the same bouncing tach that i had with the auto cluster
808B18C5
Aug 24, 2011 04:46 PM
RichardLSX
31
Jun 5, 2011 06:23 PM
soccermike
Aug 21, 2010 02:06 PM
importboi22
Nov 30, 2003 03:40 AM
