b20 ecu, p75 doesnt work well p2e single cam ecu runs good. help wtf!!!
i b20b swapped my 97 hatch, i tried running the jumper harness to obd1 and the p75 didnt run good. so i put the stock single cam ecu in (obd2 p2e i believe) and it runs pretty good. so i just bought a obd2 p75 ecu yesterday and put it in and it ran like crap. im so confused lol. a p75 should run the car alot better than a p2e as far i know. i need some opinions so help me out....
and i dont know if this makes a difference but when i plug in the p75 (obd1 or obd2) the throttle body sounds like its sucking in a ton of air. idk whats goin on
You know, when i had a b20 swap, i tried a few different ecu's...the one that worked the best, OBDI PR4. It ran much better than the P75
the pr4 is from a 90-91 integra right? isnt that obd0 or am i completely wrong? and does any1 else have any idea why my p2e works pretty good and not a p75 lol
If you read my post....you would see that i said "OBD1" What ecu do you think comes in 1992 and 1993 Integra RS, LS, and GS models??????
thats why i asked... when i looked it up here http://www.hondata.com/techecuid.html it just says the pr4 is 90-91.
The PR4 came in 90-93 Integras. There were OBD1 PR4 ECUs, but they are rare. They look like an OBD0 ECU, but with OBD1 plugs.
I'd chip whatever ECU you have an then you could try different basemaps...though you should use a DOHC map. Chipping isn't hard and doesn't take long.
