95 Civic Auto to Manual Swap Rear Mount Question
Old Aug 26, 2010 | 06:50 PM
streethondar's Avatar
Default 95 Civic Auto to Manual Swap Rear Mount Question
I am doing a auto to manual swap on a 1995 civic dx 2dr with a d15b vtec, I am using the 5 speed t-bracket. Do i need to change the rear mount that attaches to the t-bracket? My 5 speed conversion mount for the top works prefect, Just stuck on the rear bracket now.
Old Aug 26, 2010 | 07:35 PM
singledout94's Avatar
Default Re: 95 Civic Auto to Manual Swap Rear Mount Question
na your good as long as you have the upper trans mount the back mount will lne right up.
Old Aug 26, 2010 | 07:37 PM
well it dont line up... so i will see what the manual bracket does for it.
Old Aug 27, 2010 | 04:01 AM
94EG8's Avatar
Seagull Management
Auto and manual '92 - '95 D-series T brackets are the same. The rear mount itself is different, it bolts up the same, but the automatic version is significantly weaker.
Old Aug 27, 2010 | 07:59 AM
the manual t-bracket is smaller then the auto t-bracket, the manual mount sit's forward more.
Old Aug 27, 2010 | 08:13 AM
94EG8's Avatar
Seagull Management
No it isn't. The T bracket is identical, right down to the part number, 50827-SR3-010 for both. Believe me, i've done a couple of auto to manual swaps on '92 - '95 civics and that T-bracket is the same.
The mount sits the same, I ran an automatic rear mount for years until I finally replaced it with a new one, I caompared them when I changed it, they fit the same, but the manual mount has less rubber in it, part numbers are shown below:
50810-SR3-030 INSULATOR, RR. ENGINE MOUNTINGRUBBER (MT)
50810-SR3-983 INSULATOR, RR. ENGINE MOUNTINGRUBBER (AT)
Old Aug 27, 2010 | 09:02 AM
ALL-OUT's Avatar
sooo i can use the AT T-bracket and mount when i swap my tranny this weekend?
Old Aug 27, 2010 | 11:01 AM
94EG8's Avatar
Seagull Management
If its a '92 - '95 you can, although if you can afford it i'd buy a 5 speed rear mount, they're a lot stronger and the engine wont rock nearly as bad.
Old Aug 27, 2010 | 07:21 PM
Ok, The t-bracket (part no: 50827-SR3-010) is the same for a 92-95 honda civic. The manual rear mount sits up higher and leans forward more then the auto rear mount does, i just compared them today on my swap. The AT rear mount would not work, We had to use the manual rear mount with the auto t-bracket. I found out today that we were trying to use a 96-00 manual t-bracket. Which is different form the 92-95 t-bracket. That's what my confusion was. All sorted now and the car runs smooth.
lazymbf
11
Jul 15, 2025 03:17 PM
ttjdmSIR
Dec 17, 2013 11:28 AM
anzi
Transmission & Drivetrain
Feb 8, 2011 06:55 PM
Your Name
Nov 1, 2009 01:23 PM
getnasty
Nov 17, 2005 12:56 PM
