hondata S300 red light in ecu?
Old Aug 26, 2010 | 11:50 AM
90Rexx's Avatar
Default hondata S300 red light in ecu?
So the hole for my usb port on my S300 is right next to that green LED light so i can see it obviously. Occasionally when i drive the car hard, the LED will illuminate red, then go away after a few minutes. no CEL or anything.
is this normal? or is this trying to tell me theres a problem?
Old Aug 26, 2010 | 11:53 AM
joito's Avatar
Default Re: hondata S300 red light in ecu?
IDK MY BOY HAS ONE AND I SEE GREEN ALL THE TIME U MAY WANNA GET IT CHECKED OUT ASAP
Old Aug 26, 2010 | 12:17 PM
90Rexx's Avatar
ill do like, a 3rd gear pull, and the light will turn red, then go back to green after a few minutes
Old Aug 26, 2010 | 12:28 PM
mtber's Avatar
That would be on board datalogging. See if your calibration has it enabled.
Old Aug 26, 2010 | 12:47 PM
jdm inc's Avatar
x2
Old Aug 27, 2010 | 04:02 AM
90Rexx's Avatar
cool, so its not indicating a problem haha... i saw red and i was like oh noes! lol ... red means stop! lol
Old Feb 9, 2011 | 10:49 PM
215HPLSVTEC's Avatar
I just found out I have that same problem. So did u ever find out what it may cause that. Everything that happen to u the same thing is happening to me.
Old Feb 10, 2011 | 04:26 AM
Turbo-LS's Avatar
Datalogging and live tuning will flash the lights red green very fast makes it look like solid red. If its staying solid red usually an ecu problem. Verify its solid or flashing red. If flashing then your datalogging when perameters are met. If colid check ecu solder points. Could be bad connection or something wrong inside ecu. Generally when goes solid red it freezes up when laptop is connected
Old Jul 30, 2016 | 06:07 PM
boltineh3's Avatar
having the same issue but its also not letting me adjust tune or upload a tune. yes its registered in my name as well
Old Aug 3, 2016 | 09:45 PM
B and B's Avatar
Loved
Community Favorite
You should've posted in tuning forum, which probly didn't exist when this thread was last visited, lol
Or Hondata forum.
dleccord
Jan 25, 2010 07:45 PM
civiccoupe94
11
Jan 3, 2009 08:28 PM
timisyourfriend
Jan 24, 2006 12:45 PM
autoraceparts.com
Sep 26, 2004 06:27 PM
C_H_A_D
Aug 1, 2004 07:23 PM
