FS: H22A JRSC + Hondata S300 + 440CC Injectors
Alright guys,
I am going to be pulling out the charger and keep the lude the way it is. Gotta get this car ready to be a daily again before I pick up the new car. So the charger will be coming off within a week or two. This is a complete kit minus the JRSC management. Boosting on 9lbs, blower has about 5-6k miles only. I will include all gaskets. And also a 6lb pulley (if I can find it). If you would like to pick up the charger + p28 w/ hondata s300 (tuned) + RC 440cc Injectors and fuel rail + DevilsOwn Water Injection. I can do $3100 plus shipping for everything. I will also throw in OBDII to I harness conversion and injector harnesses to prevent you to splicing. Here are the breakdown prices with the kit separated.
JRSC - $1900 picked up
P28 w/ Hondata S300 Tuned + PnP OBDII to OBDI Conversion Harness - $700
RC 440CC Saturated Injectors + PnP Harness - $250
AEM Fuel Rail + Marshall Gauge - $100
Devils Own Alcohol/Meth Injection + Tank + 3gallon - $325 picked up only if Al/Meth is needed.
pictures will be posted shortly. once I get everything pulled out.
^^^ no the hondata does not come with a boost solenoid. The ecu is capable of incorporating that in. I did not need that for my setup on my supercharger.
Injector with pnp harness - Pending
OBD II to OBD I Harness - Pending
but you wouldn't be able to boost by gear without having a solenoid hooked up correct?
I believe that is correct. I'm not too sure about that tho. But since I was boosting with a supercharger, I have no requirement to connect the solenoid since I don't have a wastegate. But that option can be added through vendors that does chipping as well as hondata themselves for a small fee.
MOGSR
Jan 26, 2002 08:00 PM
