what material to use for "splitter" chin-spoiler?
Old Aug 26, 2010 | 05:44 AM
Charlie Moua's Avatar
Default what material to use for "splitter" chin-spoiler?
I've been toying with the idea of making a front chin spoiler "splitter" for my EF.
Many track guys swear by them and say they help with higher speed stability at the track.
I would like to try and make one myself, but not out of cheap plywood...lol
It would have to be thin, stronger than plywood and the lighter the better. CF is out of the question, but i'm sure there is some sort of hard plastic that could be cut and sanded down.
Even if the material is more expensive then wood, i'm sure it will look nicer, be stronger and last longer. I'm thinking it should not cost more than $100 for supplies. (bolts, brackets, washers, board material ect.
Any thoughts on this?
Links would be greatly appericated too.
Charlie Moua
Old Aug 26, 2010 | 07:12 AM
weiRtech's Avatar
OG Fabricator
Default Re: what material to use for "splitter" chin-spoiler?
i'd go with a plywood core covered in cf.
Old Aug 26, 2010 | 08:45 AM
RickyLee53's Avatar
How big and functional do you want it to be? I think you'll struggle for $100 to find anything better than plywood.
Old Aug 26, 2010 | 09:27 AM
90Rexx's Avatar
try a big sheet of plexiglass. its similar to ABS plastic. might run over your budget though, and will need to be wrapped in carbon fiber or something like that
Old Aug 26, 2010 | 03:02 PM
why do people say that it needs to be wrapped in CF?
I recall seeing some custom ones that look just flat black and may be only 5-8mm thick or so...
Old Aug 26, 2010 | 03:16 PM
TunerN00b's Avatar
Alumalite, AL and fiberglass, frequently used in making signs, should be available relatively cheap.
Old Aug 26, 2010 | 03:28 PM
powerneedy's Avatar
Stiffness... A balsa core or honey comb core wrapped in carbon is extremely light but also extremely rigid. Plastic is going to not work very well unless you run something thicker but then weight will come into play... Mines wood with epoxy resin on top and its pretty rigid and fairly light and CHEAP... If you want hit up your local sign shops for old signs out of alumalite. Its 2 thin sheets of alum with a plastic honeycomb in the center. Its light still and on the cheaper side
Edit damn tooner noob beat me
Old Aug 26, 2010 | 05:26 PM
88Hatchy's Avatar
http://www.defender.com/realcategory...6458&id=309319
^This, with either carbon or fiberglass overlay. Use a slow-set epoxy and vacuum bag.
Old Aug 26, 2010 | 09:50 PM
niteridaV2's Avatar
Yep,
1/8" foam core with fiberlgass wrapped around it. No need for a vac bag if you just get full wet-out.
I get 1/8" foam core for $55 for a 4X8 foot sheet, and you could do it with another $30-40 of e-glass and resin. Don't bother with epoxy resin though, waste of money, especially unless you have advanced methods of doing the lay-up.
Polyester resin works great, and it is cheap.
Old Aug 27, 2010 | 02:33 PM
redboost10's Avatar
whats wrong with some .080 aluminum? or uhmw plastic or lexan if you wanna stay with plastic
Old Aug 28, 2010 | 02:38 AM
naterpatater77's Avatar
i dont know whats wrong with "cheap" plywood. if you f-it up youre out a whopping 10 dollars
my current splitter/airdam yes its plywood , splitter is .451" ply and the airdam is .050alum figure id throw this out there for ideas.
as far as strength me and my buddy can stand on it total weight 300+ lbs. And it the whole splitter and brackets weigh less then 15 pounds. Is there a reason youre opposed to making one out of cheap plywood, I mean if its used on the p1 spec splitter from spms it cant be that bad.
Old Aug 28, 2010 | 10:36 AM
skellator_thoj's Avatar
1/8" foam core splitters are light but will break easier and flex/bend at higher speeds unless you have a good mounting point system, but that means more mounting points and or thicker rods/tube/pylons=more weight. I recommend at least .25 foam core or 3/8 balsa wrap in fg or cf and call it a day.
Originally Posted by niteridaV2
Yep,
Old Aug 28, 2010 | 02:13 PM
essex's Avatar
your airdam for that eg is too big, you should build the air dam after you lower the car and set the ride height now you got about 4 or 5 inches of air dam I think it'll be too tall for you.
Old Aug 29, 2010 | 12:55 AM
dai-18t's Avatar
I don't know much about air dam heights and what not but thing looks like it is built rather well for what it is.
Old Aug 29, 2010 | 10:12 AM
hondalover91crx's Avatar
right, cause there is no possiblity that he thought it out before hand, or seems like a relatively competent individual..... you know it really blows my mind when people feel the need to tell someone else what they are doing wrong. im sure he knows full well what height he wanted it. shut your flappy mouth.
Old Aug 29, 2010 | 12:29 PM
essex's Avatar
These eg bumpers are pretty low so you can actually just use a lip no need for such a big air damn the splitter looks great i'm just pointing out the air dam might be tall.....but yes its great work, so please Relax.
Old Aug 29, 2010 | 07:21 PM
im fully relaxed. ive owned plenty of eg's. now lets assume that this is a track prepped car, and this track prepped car is going to be running a rotor over 12" thats going to require a 17inch rim, not to mention hopefully a wide 17" rim at that. the car is not going to be "slammed" by any means, or he is going to sacrifice steering angle. now all of a sudden a "lip" even a low one (ie jays racing) is not going to be very close to the ground. look at any properly track prepped eg with a big tire and big brakes. your a dope. it looks fine. keep up the good work naterpatater77.
Old Aug 30, 2010 | 05:00 AM
thanks!
actually the splitter blade sits about a half inch lower than my jdm **** spoon replica lip the reason the airdam looks so big is that well about 3 inches of that is covering the bumper believe me it has fully been thought out i will be running 15x8 949 racing 6ul wheels wrapped in 225/45/15 nt01s
here is when i decided how low i wanted it to sit
i didnt want it too low so that when i actually get up to speed that the downforce this will create will not pull it too close to the ground
and my car is probably not going to be much lower than when i first lowered way back in the day
Old Aug 30, 2010 | 07:50 AM
red_crx's Avatar
I would just stick with plywood....In most cases the splitter will rip completly off incase of an "off" on track. I use the same marine grade plywood that came with my P1 splitter setup and it holds up fine; I've gone off track a few times at over ~60mph and its still good.
Pic of it now:
Old Aug 30, 2010 | 11:10 AM
Austin's Avatar
I went through 3 Playwood Splitters, shattering 1, breaking 1 on a burm, and another one that was ripped off while going off-track. I'm now on my 1st Alumalite splitter, it's been on there for a while, I'm quite happy with it, and I lost some weight from the car.
Old Aug 30, 2010 | 11:21 AM
what is the name of the marine grade plywood that spms uses?
Old Aug 30, 2010 | 04:48 PM
ej1 rep's Avatar
ummm......1/8" aluminum or steel???? Thats the only thing I would use
Old Aug 30, 2010 | 04:57 PM
cluelessmale's Avatar
we had stuff at my last job it was kinda like plastic, we called it black board. It came in 1/4, 1/2, 3/4, or 1in.
Old Aug 30, 2010 | 07:13 PM
need more brakes!
Old Aug 31, 2010 | 01:22 AM
jere's Avatar
Nacar Tegris $25
http://www.motoiq.com/forum/aff/82/a...afnp/6638.aspx
