Torsen lsd - reversed rotation?
Works just fine. I have an OBX D series diff in the rear diff housing on my Wagon, and it works. However, my suspension right now is allowing the rear inside wheel to unweight enough coming off a corner that the diff will unload under power. I will try stiffer front springs next. I'm at 672lb (12 kg/mm) springs right now but will try 728lb (13 kg/mm) next. I also have a 24mm front ST bar. Anyone know someone that can bend me an OEM style/fit EF/DA front bar in 26 or 27mm?
If suspension tuning doesn't fix this, I'll be faced with switching to a KAAZ or Cusco (or some other kind of plate style diff). I would love to try the Wavetrac, but they don't have a D series application. Anyone else interested in a D series Wavetrac? If we have enough people interested, we could convince Autotech to make one.
Here's a pic while I was test fitting and modifying the OBX to go into the Wagon housing:
I will not install a rear sway bar yet. I don't want to sacrifice any rear traction until I have a better understanding of how well the rear suspension can put down power. I have raised the front spring rate, and will raise it more. I will also try a larger front bar. I'll keep going until I start losing front traction. So far it's not been an issue.
I cannot go lower on rear spring rate, as I need to control a tire rubbing issue in the rear. Softer srpings will make the rubbing worse.
The rear diff modifications were quite simple. Drill out the threaded ring gear bolt holes. Period.
ceepandas
Transmission & Drivetrain
Jun 9, 2014 03:11 PM
Shut It Fool
18
Jan 26, 2011 04:51 PM
