BRAKE PROBLEM
Old Aug 25, 2010 | 11:57 PM
esahic's Avatar
Default BRAKE PROBLEM
I Got a 97 ex coupe. It had drum brakes so I decided to upgrade to disc,found a really good deal on a itr 5lug, so I swapped that in. Got new stainless steel brake lines and I tool it 4 a spin today and I heard this CLIKING NOISE coming from the driver side wheel!!! =0 now it only makes the noise when I apply the brake and I'm slowing down! Can any1 tell me what it might be or what to do?thanks...
Old Aug 26, 2010 | 09:06 AM
esahic's Avatar
Default Re: BRAKE PROBLEM
I was going to mess with it and see what was wrong, but i got called into work today! dammit. Hope someone could help.
Old Aug 26, 2010 | 09:09 AM
Former User's Avatar
You might want to check whether the wheel splash guard is bent and hitting the rotor.
Old Aug 26, 2010 | 07:42 PM
esahic's Avatar
Thank you for the suggestion. I will check that tomorrow morning and let you know.
Old Aug 27, 2010 | 08:02 AM
esahic's Avatar
Its not the splash guard. Any1 else. Remember this clicking noise is coming ONLY from the driver side wheel and ONLY when i press the brake when driving. HELP! Not sure if it safe to drive!
Old Aug 27, 2010 | 09:03 AM
Green Crack's Avatar
Did you check if the rotor was warped?
Old Aug 27, 2010 | 09:20 AM
instructor74's Avatar
Well it could be a lot of things I would check and make sure every thing is tight esp ball joints
b20acura
Jun 28, 2011 12:20 PM
esahic
Suspension & Brakes
Aug 28, 2010 02:18 PM
epeen
Nov 29, 2006 06:03 PM
.M.
May 19, 2005 01:03 PM
