95 civic: how remove crank pulley?
Old Aug 25, 2010 | 10:35 PM
laloquera916's Avatar
Default 95 civic: how remove crank pulley?
First time doing a timing belt on civic, how do get the bottom pulley pulled off. I got a special tool to take off the pulley for my cb7 and crv, but this civic has a differrent pulley on there. Anyone got a good write up with pictures before I get started on it tomorrow before I break stuff. Thanx
laloquera916
Old Aug 25, 2010 | 10:41 PM
hondawhiz's Avatar
Default Re: 95 civic pulley
im guessing ur doing it on a eg cuz alot of them dont use the 50mm hex. what you could do is take the dust cover off the tranny, and put a 12 mm wrench in between the flywheel and the casing making sure the teeth grab the round part of the wrench and after you turn the flywheel theres a point where it gets stuck. and you can break the bolt loose. eazy
Old Aug 25, 2010 | 10:57 PM
Really? Never heard of this method before, is it affective? Sorry about sounding abit skeptical but Im willing to try it. Wont the flywheel get damage, teeth bent or break off. I beleave the pulley bolt has 85lbs of torque?
laloquera916
Old Aug 25, 2010 | 11:15 PM
hondawhiz's Avatar
i think the pulley bolt has 85 up to 130. but its worked for me every time. no damage what so ever. i dont have a pic so u can see. but i hope u get the idea. the wrench should go towards the back of the engine with the round part of the wrench into the teeth. u might need a friend to help you hold it there.
Old Aug 25, 2010 | 11:26 PM
I kinda picture it in my mind! Im gonna wanna go counter clockwise? I'll post up my results here tomorrow night. Where and how did get this technique?
laloquera
Old Aug 25, 2010 | 11:28 PM
hondawhiz's Avatar
i got it when i couldnt take off my homies crank pully from his civic 94 hatch. cuz the pulley just has alot of little holes in it, so my old buddy said try hooking the flywheel with a wrench, and he was right. i used this method on acura integras as well. never failed. and yes counterclockwise. you will be surprised. how effortless it gets.
Old Aug 25, 2010 | 11:45 PM
Right on! U got me sold on the idea! Wish me luck and thanks agian.
Peace in the middle east my brother
laloquera
Old Aug 26, 2010 | 06:16 PM
Default Re: 95 civic: how remove crank pulley?
IT FREAKING WORK! Thanks. So do I lock it up agian to torque it down the same way?
laloquera916
Old Aug 26, 2010 | 06:53 PM
lunareg's Avatar
yeah I usually just stop the flywheel, works like a charm
Old Aug 26, 2010 | 07:44 PM
hondawhiz's Avatar
you can do that. just dont over torque it.
Old Aug 26, 2010 | 09:09 PM
I have an extra timing belt from 92 cb7, does it fit into the 95 civic. Also I need a write up, not sure about the timing marks.
laloquera916
Old Aug 27, 2010 | 07:22 AM
hondawhiz's Avatar
that timing belt wont fit the civic. its giant. which timing marks? for the cb7 or the civic?
Old Aug 27, 2010 | 08:01 AM
Crap, u maybe right. I’m trying to compare both belts, but the civic belt broke into three pieces and is missing a few grooves. Everything matches up, except the diameter for the civic belt. I may go get a new one, hate to do things twice.
As for the timing marks, dont sweat it, did a search and found a good research to read up last night. Thanks agian.
laloquera
Old Aug 27, 2010 | 12:31 PM
Got a new timing belt from Cragen, # T224 or TX224. But its abit short and have loosent the tentioner to the fullest and still cant get it on. I think they may have sold me the wrong belt. Can anyone verify this?
laloquera916
Old Aug 27, 2010 | 12:42 PM
24TEN's Avatar
PHANTOM MENACE
What motor is in your car?
Old Aug 27, 2010 | 12:49 PM
Sorry, had down a quick taco. Its a D15B7 engine.
laloquera916
Old Aug 27, 2010 | 12:53 PM
24TEN's Avatar
PHANTOM MENACE
According to Kragen's site, T224 is for the Si/Z6 engine. That would explain why it doesn't fit (Z6 belt has a couple less teeth on the timing belt compared to the B7).
Old Aug 27, 2010 | 12:55 PM
Shoot! I just called Cragen, according to engine code, they gave me the wrong timing belt. Thanks!
laloquera
Old Aug 27, 2010 | 12:57 PM
I think they said it was T143. Yeah my cb7 timing belf its abit bigger diamator size. Either way, thanks.
laloquera916
Old Aug 27, 2010 | 03:58 PM
Im back & still on the timing belt job. Anyone know how to put back the a/c belt tensioner? Ive tried putting back on and it freezes up, Am I going to tight with it or am I putting wrong. Didnt get a chance to look at it, it just fell apart and did not have a chance to notice how it was set up. Anyone?
laloquera
Old Jan 21, 2020 | 12:37 PM
Anthony Newlin's Avatar
hey I believe I have an aftermarket crank pulley there is no indent for the crank to to slip in there and stop it from cranking there’s just small holes around the pulley any suggestions?
Old Jan 21, 2020 | 01:21 PM
NukeNinja's Avatar
Put the car in gear and have your partner hold their foot on the brake.
Old Jan 21, 2020 | 01:23 PM
tried it didn’t budge I’m all kinda new to this but I can tell it’s definitely been changed before due to that crank pulley still spun
Old Jan 21, 2020 | 02:17 PM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
Its usually best to start a new thread rather than bumping a 10 year old one, however if you have access to compressed air and an impact gun get a Honda crank pulley socket (or harmonic balancer socket). Google it.
eH.
Dutch_commando
11
Jun 24, 2017 08:26 AM
accord2civic2prelude
Nov 1, 2009 04:22 PM
SpOoLiNg CiViC
Jan 2, 2007 05:13 PM
88 dx
13
Aug 19, 2005 10:30 AM
BoostedED9
Jun 16, 2002 06:45 AM
