Aftermarket Catalytic Converter and CA smog
Old Aug 25, 2010 | 10:01 PM
ware's Avatar
Default Aftermarket Catalytic Converter and CA smog
I have a 2000 honda civic ex that has a bad catalytic converter and my smog check is due soon. My car is completely stock, no modifications what so ever. My question is, will my car pass (sniff test) with an aftermarket cat such as the one in the link below? The visual part doesn't matter. I am in the state of California.
http://cgi.ebay.com/ebaymotors/HONDA...Q5fAccessories
Old Aug 25, 2010 | 10:09 PM
anzh86's Avatar
Default Re: Aftermarket Catalytic Converter and CA smog
probably not since it came from ebay. try magnaflow if you wanna go aftermarket
Old Sep 26, 2010 | 12:43 PM
ware's Avatar
Anyone pass the sniff test with aftermarket cat? I'm not worried about visual, just the fumes reading. Thinking about getting this, any suggestions?
http://www.performanceexhaustplus.co...nda-civic.html
Old Sep 26, 2010 | 01:34 PM
kevinm1981's Avatar
Yeah you would pass with that IMO. Those are epa certified.
Old Dec 22, 2010 | 09:00 PM
HatchbackSqueegee's Avatar
anyone ever try and aftermarket cat to pass smog? And im not talking about ebay crap or hi flow.
Old Dec 23, 2010 | 04:39 AM
rhymeshark916's Avatar
Either go OEM or Magnaflow. No cutting corners. Good luck especially OBD2's are very pricey. I bought my obd1 gsr cat. for $160 and had to get it weld it on. Cheap alternative is to find a good used one from your local Honda recycler. My friend bought a used Civic Ex for $100-$120 I think and it came with a sensor.
Old Dec 23, 2010 | 08:15 AM
B18CivicEJ8's Avatar
http://www.arb.ca.gov/msprog/aftermk...ftermktcat.htm
Those are the rules for your car that you need to follow in California to replace your catalytic converter. There's a specific Magnaflow one you'd need if you went aftermarket:
http://www.car-sound.com/04basics/04california.asp
Old Dec 23, 2010 | 08:22 AM
Well, you might pass the sniff test, but you would not pass the visual inspection at all cause they will look for specific CARB numbers that will be stamped on the bottom of aftermarket cats.
If you want magnaflow, you'd need this specific cat:
http://www.car-sound.com/02product/d...irectfit=46630
That is the only way you'd pass inspection.
Old Dec 23, 2010 | 08:25 AM
According to the rules I posted, you cannot buy a used one either. It is even illegal to sell used cats in California.
Old Dec 23, 2010 | 08:50 AM
CivicSD's Avatar
it may be illegal but it doesnt stop the junkyards from selling used cats all day long. used honda cat is your best bet, thats what I do and it works everytime.
my current car came with some ridiculous aftermarket cat thats tack welded in with exhaust leaks and everything, and even that passes smog
La Zona Imagery
May 23, 2016 11:05 PM
beginmyhonda
14
Dec 13, 2009 10:24 PM
Monochild
May 21, 2005 07:41 PM
b00sted4dr
Feb 1, 2003 09:45 AM
