98 JDM H22A wont turn over
Old Aug 25, 2010 | 06:21 PM
dirrtybirdy's Avatar
Default 98 JDM H22A wont turn over
I got a new battery cause the battery was drained. I tried swapping the dizzy and still no go.
When I put the car in accessories I cant hear the engine prime.
My car has been sitting for a couple months. Im running out of options here. My friend and I dont know whats wrong. It sounds like it wants to turn over but doesnt. Can anyone help me troubleshoot the problem?
Old Aug 26, 2010 | 06:04 AM
ilikehonda's Avatar
Default Re: 98 JDM H22A wont turn over
do you have spark? Fuel? does the car turn over?
Old Aug 26, 2010 | 01:42 PM
Stupid_hyundai's Avatar
did you check if youre getting spark from the coil? you can do so by touching the end of the cord coming from the coil to the block, frame, panel, someting metal and have someone try to start it and see if it arks if not replace the coil. but make sure the motor is cranking, if its not then pull the starter out and replace it. if motor is cranking then check your timing belt by taking the vc and crank it if the cams dont turn then your timing belt is broke. trust me i just went trough this whole thing i replace the coil, icm, rotor, and cap and still no spark so we checked and the timing belt was broke. hope this helps
Old Aug 26, 2010 | 01:45 PM
hondawhiz's Avatar
was the car running before?
graevz
May 21, 2016 03:02 PM
Munkeyjdm86
Feb 4, 2014 07:21 AM
Pworld925
Dec 31, 2011 12:24 PM
junya16
Mar 1, 2003 05:41 PM
G a b e
Dec 14, 2002 09:29 PM
