Transmission & Drivetrain Gearboxes, Differentials, Clutches
Axle Trouble..need some help please
Old Aug 25, 2010 | 05:57 PM
92sully's Avatar
Default Axle Trouble..need some help please
ok i went to put my stock passenger side axle back in which is the half shaft...it will not go into the transmission all the way. when i look into the tranny there is like a black tube thing blocking the way of the axle...when i turn the car on the black thing moves in a circle...spins.. what is it and how do i get my axle back into my tranny..thank you
Old Aug 25, 2010 | 06:35 PM
Krut's Avatar
Default Re: Axle Trouble..need some help please
Thats the spider gear cross shaft, open diff transmissions have these (non lsd). Your axle should pop back in sometimes they are a little tricky, have you tried tapping it in with a hammer?
Old Aug 25, 2010 | 06:53 PM
hondawhiz's Avatar
make sure the pop ring on the tip of the axle is not all wobbly. it should pop in. try sliding it in and out going hard when you push it in
Old Aug 25, 2010 | 07:09 PM
92sully's Avatar
ive tried hitting it in with a hammer didn't do anything...so that shaft is supposed to slide out of the way? becuase it doesn't feel like it moves..
Old Aug 25, 2010 | 09:02 PM
hondawhiz's Avatar
no it stays there. how far in does it go in?? if it goes more than half of the chrome shaft you need to make sure you kinda twist it in and you can use the same axle as a "slide hammer" to kinda pop it in..
Old Aug 26, 2010 | 08:31 PM
92sully's Avatar
im about a half inch less...it would go in but that black piece is in the way and i doesnt feel like it will move
Old Aug 27, 2010 | 07:00 AM
hondawhiz's Avatar
are you using the same axle?
Old Aug 27, 2010 | 06:59 PM
93h2beg's Avatar
THAR BLACK PIECE WILL NOT MOVE, IT IS SUPPOSED TO STAY THERE. ITS A FACT, FORGET ABOUT IT, THAT IS NOT YOUR PROBLEM!!!! Yes i was talking loudly. push the axle in as far as u can get it, use a scrap of wood and pound the axle in with a hammer using the wood as an insulator so the hammer does not damage the axle, twist and repeat till done!
Old Aug 28, 2010 | 06:56 PM
92sully's Avatar
Yes same axle never took it off the hub....that hammering did not do anything at all. it will only go in so far and that black piece is not moving at all...so if anyone can help me out heres some pics finally guys.. thank you as well
Old Aug 28, 2010 | 06:58 PM
92sully's Avatar
here they are
Old Aug 28, 2010 | 08:22 PM
hondawhiz's Avatar
if your talking about the stick in the middle of the spider gear, thats normal, but if the actual part that grabs the ridges of the axle is getting in the way, then the differential fell of its place. so its not good anymore.
Old Aug 29, 2010 | 03:22 PM
92sully's Avatar
No I can't get my axle past that black piece in the middle there
Old Sep 15, 2010 | 01:09 PM
Importordomestic's Avatar
you are an idiot... read the service manual. Grow a pair of ***** and hit the damn thing with a effin hammer.
in the future take your car to a real mechanic.
Hoppa
Dec 5, 2006 08:51 AM
huepowered
Mar 27, 2006 12:33 PM
The Phil
Aug 26, 2005 10:33 PM
SoOHiGH
18
Jul 6, 2005 07:48 PM
vha27
Nov 17, 2003 07:27 PM
